| Notices |
| Electronic Projects A collection of small electronic circuits and projects you can build. |
| | #61 (permalink) |
| Experienced Member Join Date: Jul 2007 Location: Winnipeg, MB, Canada
| Here's an idea for those doing this with a PIC or other micro. To add a bit of evilness, setup the PICs internal timer1 as a makeshift RTC and have it chirp at random intervals between 1 and 10 minutes. You could also choose a random frequency to drive a piezo speaker. If it chirps with a predictable period, it is probably more likely that your device will be discovered. |
| | #65 (permalink) |
| New Member Join Date: Apr 2008
| Hi , so I got a 6V DC mini buzzer. I tested the buzzer just connected to a 1.5V battery. And it worked. But when i put a resistor of even say 220 ohm in the path of the buzzer and battery, it stopped working. (maybe its making very dim sound). But with the whole circuit It doesnt work at all. Any help? Thanks |
| | #67 (permalink) |
| New Member Join Date: Mar 2008
| Better make sure the victim has enough sense of humor so your poor electronic cricket doesn't get stepped on if he finds it- That would be the advantage of the cheaper and less elaborate circuit, if it does get found, more disposable- I've encountered real life crickets that would be a good model for what this should do- chirps away happily until you get close trying to find it, and then it stops, only to resume when you get tired of standing around waiting for more clues as to where it is, and walk away. Maddening. |
