Old 18th July 2006, 10:38 PM   #46
Above your supply voltage, so 2 volts and up.
Originally Posted by hartc2697
I'm not able to get the circuit to pulse on/off as I would expect. Rather it constantly stays on. Do I have the wrong expectations of this circuit?
I had thought this circuit created a pulsing of beeps.
If I'm wrong, could someone point me in a direction of how do accomplish the pulsing chirps? Thanks in advance.
Does it work otherwise? Turn on after some time in the dark and turn off in light? If so you'll need a different kind of buzzer. You're not using a speaker are you?
uzzors2k is offline
Old 20th July 2006, 12:59 AM   #47
Default oke-poke
uhh...
noob question but i cant get it to werk at all... :sad:
im using a 3904 and a 4011 as the transa. is this wrong??
tyeo000 is offline
Old 24th July 2006, 04:48 PM   #48
what would be the values of the capacitors being used to this project?
please send me a reply as soon as possible coz i want to do it as my project in my electronic subject....
Jhoneil Dan is offline
Old 28th July 2006, 07:51 AM   #49
i used 2 bf194 transistors n a 9 volts battery......the circuit din work.....can some1 plz help me out
scotchbrite is offline
Old 28th July 2006, 03:25 PM   #50
As we discussed here, the circuit is poor because it is missing a very important current-limiting resistor. With a 9V battery instead of the original 1.5V the excessive current probably destroyed the 2nd transistor's base-emitter the moment the battery was connected.
audioguru is offline
Old 30th July 2006, 02:50 PM   #51
I made one substantially more evil. It was a really high frequency whine and at the higher frequencies it's almost impossible to locate the source in a closed room.
It was designed so it went off after being in the dark several minutes, ran for under a sec, and repeated every few min. 10 sec is way too short a period and they will immediately realize it's associated with light which blows the whole gag. Several minutes and they will not realize it. You just need to make sure the period is not so long that they might fall asleep without hearing it or maybe only hearing it once, which may not arouse their interest in finding the source of the noise. So a period under 10 min is desirable.
Ideally the period should be substantially longer at first when the lights go off, giving them a feeling that the problem has gone away.
Oznog is offline
Old 8th August 2006, 09:58 AM   #52
ok provide me the PCB of NIGHT BUZZER.
ishank thandi is offline
Old 8th August 2006, 03:23 PM   #53
Originally Posted by loveangel4943291
loveangel4943291@yahoo.complz i want to find a design for counter which count the number of papers go out from the copy machine and stored the number of copies in small memory plz tell me ur suggestions about this project
OMG! How these off-topic, bizzare requests get injected here is beyond me!!! LMAO!
[kneels down with head bowed] "God in heaven, please don't allow these people to reproduce. In all your perfectness, I fail to understand how these amoeba-like people manage to durate on this planet." Amen!
HiTech is offline
Old 8th August 2006, 03:27 PM   #54
By the time you muster up a PC board, you could have this simple circuit breadboarded a dnworking in half the time.
HiTech is offline
Old 21st September 2006, 05:10 PM   #55
Pls I Will Like To Try This Hence Its Fun But Am Just A Beginner Can I Have A Simpler Diagram And A Better Guide To Construct It. Also The List Of The Components
casdon56 is offline
Old 3rd February 2007, 09:10 AM   #56
I've attached a PCB board for the buzzer. Somebody please check if it works.
Project: Night Buzzer-buzzer.gif
snareklutz is offline
Old 8th February 2007, 07:26 PM   #57
Ha ha haaaaaa. This is funny CCT. OMG Its very very funny. Hmm one of my friend is very mad at me now. Coz of this. Hi hi heeeeee.
pasanlaksiri is offline
Old 10th March 2007, 04:24 AM   #58
Originally Posted by bryan1
Eh Zac,
Thats a wicked little circuit mate, time for me to make one up as the family's gone out for the day and when my son goes to bed tonite :twisted: we can say he's just hearing things in his head. Although when my missus finds out I reckon I'll break the 3 minute mile just running away.
Cheers Bryan1
It will be very difficult to find out the circuit in dark if you choose a buzzer with frequency more than 5KHz.
tanmaysathe is offline
Old 18th March 2007, 09:13 AM   #59
Default can I use S9014 transisistor
hello there,
can I use s 9014 which is an npn silicon transistor as I am not able to find 2n 3904 at my place ....I have got a few s 9014 can I use them
nightcatz is offline
Old 11th February 2008, 04:49 AM   #60
which LDR do you use?
kaibui is offline
buzzer, night, project
