Thread Tools Search this Thread Display Modes
Old 14th December 2004, 04:49 AM
Experienced Member
zachtheterrible is on a distinguished road
Send a message via AIM to zachtheterrible Send a message via MSN to zachtheterrible
Default Laser or IR beam alarm system
This is a cool little circuit that i made for a school project. It can be used as one of those things that is usually seen on the door of small shops so that when someone walks in it goes "ding dong". It could also be used as a burglar alarm (just need to get a loud enuf siren).
A light has to be pointed at the LDR. It can be anything, just as long as its bright enough. Im pretty sure that an infrared LED would work, a regular light, or my personal favorite: a laser pointer, just like in the movies 8) . You could encircle your house w/ a laser so wen someone crosses the beam you know.
R1 can be adjusted for sensitivity of the circuit to light. The lower R1, the more sensitive, and vica versa. The value of R1 will not allow the circuit to work in direct or indirect sunlight. R1 would have to be increased to make the circuit less sensitive to light (even then i doubt it would work in direct sunlight). An alternative to this is putting a tube on the LDR that is a couple centimeters long so that only light from the light source could get in.
R4 can be adjusted for how long the buzzer stays on. 100k makes it stay on for about 9 seconds. Or the value of C1 could be adjusted.
Someday i plan on putting a transmitter on the circuit so that it could be put out in the yard, and a receiver inside would go off. HAVE FUN :lol:
zachtheterrible is offline   Reply With Quote
Old 29th January 2005, 02:42 PM
Dexel is on a distinguished road
Send a message via Yahoo to Dexel
Default Help Please!
Pretty nice design. I made one myself but it only has three components. A resistor, transistor, and a photo transistor. I wired it so that I have an input of 220watts and an output of 220watts(so I can use either a radio or a lighting fixture or any appliance running in 220watts) I've been having loads of fun with it but there's just one problem. It turns off as soon as you leave the beam so I want to install a time switch and have it run for a few more seconds after its turned on. Can you help me? I don't know what to add to give it that effect.
Dexel is offline   Reply With Quote
Old 29th January 2005, 10:05 PM
Experienced Member
you're using it as an alarm, so that when someone crosses the beam the radio or whatever will turn on, right?
Well, thats the whole point of my design is to have a buzzer stay on for a couple of seconds after the beam has been crossed. Just use a power mosfet, or something that can handle 220 watts in place of Q4.
Old 13th April 2005, 05:46 AM
jawpring is on a distinguished road
Send a message via Yahoo to jawpring
Default hi
could you give me a schematic diagram or anything that i could photocopy in a photoPCB so that i could make also a project.thank u
im kenrick isleta from lorma and im a handsome gwapo
jawpring is offline   Reply With Quote
Old 14th April 2005, 01:20 AM
Experienced Member
theinfamousbob has a spectacular aura about
Personally, I would use a 555 wired in a monostable (one-shot) config and use a potentimeter to control time delay... Not sure if this design would have any benefits but I thought it would be worth mentioning.
Cheers.
-Ian
theinfamousbob is offline   Reply With Quote
Old 14th April 2005, 02:44 AM
Experienced Member
Cheers.
dont let me stop you :lol:
Old 15th April 2005, 10:42 PM
Experienced Member
Roboticinfo is on a distinguished road
Send a message via AIM to Roboticinfo
Default reply
Try this website
http://www.commlinx.com.au/schematics.htm
They have alot of circuits including laser and IR
Robotics is heaven in my book.
Roboticinfo is offline   Reply With Quote
Old 15th April 2005, 11:01 PM
Experienced Member
Hey GTA, where are you located in California? Im in Temecula.
Old 16th April 2005, 01:47 AM
Experienced Member
Default reply
I live in san fransisco california
Old 17th May 2005, 07:45 AM
bryanperito is on a distinguished road
Send a message via AIM to bryanperito Send a message via MSN to bryanperito Send a message via Yahoo to bryanperito
Default Re: hi tumor babalusay air
hoy edison tilan samet pappapanamon nga site pra lang makakita ng project ha...hehe gagooooooo..tukmol
bryanperito is offline   Reply With Quote
Old 17th May 2005, 01:07 PM
Experienced Member
DirtyLude is on a distinguished road
How long do those cheap laser pointers last? The control circuitry is just a simple resistor and I'm worried about the diode burning out if I plug it in 24/7. Otherwise I'd like to make up a simple light beam trip wire myself.
Mark Higgins
DirtyLude is offline   Reply With Quote
Old 17th May 2005, 08:57 PM
jax1492 is on a distinguished road
what would you suggest for a reciever so you could recieve a signal inside i kinda need to do something like that.
thanks
jax1492 is offline   Reply With Quote
Old 17th May 2005, 10:23 PM
Experienced Member
Default reply
Try this website
Old 18th May 2005, 01:07 AM
Experienced Member
Wow, i havent gotten any comments on this in a month or so and then BAM, 4 comments :lol:
I am very sorry for not answering your question earlier jawpring. Unfortunately I cannot give you the PCB because it is in the .bmp format, and i convert it to .gif, the size changes, rendering the PCB useless. Very sorry about that :cry:
Just as long as a regular LED would, which is very very long :lol:
I don't really know what you mean. Define receiver, my circuit, the light dependent resistor, do you want to make some sort of wireless system . . .???
Old 18th May 2005, 11:23 AM
yes, in the original post you say that some day you would like to put it in the yard and have a reciver in the house, i was wondering if you could suggested a way to do this.
Search this Thread:
Advanced Search
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
