| Notices |
| Electronic Projects A collection of small electronic circuits and projects you can build. |
| New Member | sorry for the double i cant get any of these to werk on my breasboard... i guess its time for some new transistors... |
| New Member | use power MOSFETthat the right way. |
| New Member | Sorry to bring up an old post, but I am looking to create this system and in addition have it sound an alarm inside my house. For instance, whenever a car pulls up into the driveway an alarm tells me. I think that the easiest way would be to use a simple FM transmitter instead of a buzzer, though I'm not completely sure; I would be picking up the signal a a standard radio and excessive static could be annoying. Any suggestions and Schematics/other help? I'm a noob to electronics past incredibly simple stuff. Thanks. |
| New Member | i think ur circuit is great but here you cannot given the value of transistors(NPN,NPN,PNP) plz given the value of these transistors in this circuit i hope u understand my question
__________________ Cool Jasim |
| New Member | hello hi, am very new ere.... so please explain about this laser working principle...... i saw that circuit diagram....... just there is buzzer only.... but wer is laser light.... please help me... |
| New Member | ello hi sir, am very new ere..... and i saw your circuit diagram.... what is the purpose of that circuit connection....... please give details ...... where do we connect the laser? |
| New Member | how can i connnect the laser beam and where? i'm very confused..... |
| New Member | Thanks, Im not familiar with transistors used in the circuit. can i use any transistor as long as it is NPN or PNP? |
| New Member | Quote:
in this circuit using LDR(light detected resistor) when light fall on it then it resistance high and when light not fall then it,s zero resistance and this is work like Laser beam i hope u understand
__________________ Cool Jasim | |
| New Member | Quote:
In this Circuit you didnot give the value of NPN,NPN,PNP transistor. Plz show the value of these Transistors . Have a nice day GOOG LUCK.
| New Member | Quote:
| New Member | do you know laser power supply |
| New Member | i tried a few of the links on this thread and the are dead, anyone know why? |
| Super Moderator | Quote:
| New Member | Newbie here! Help, I apologize in advance if this is the wrong place to request help and Info reguarding Infrared LED Sensors. I'm trying to custom build a Wireless Sensor bar to replace the wired sensor bar that comes with the Nintendo Wii System. With a projector instead of a TV, the cable is not long enough and I have seen on other sites a homemade wireless IR LED Sensor bar utilizing 4 IR LEDs with 4 AA Batteries. I would like to utilize a AC adapter instead of batteries. Can anyone make a recommendation as to a wiring scheme I should follow with utilizing four of Radio Shacks #276-143 IR LED(1.2 volts ea). Do I need a resistor in line? I have several ac adapters left over from obsolete electronics, calculator chargers etc.. I have a DC 4 volt, or a 9 volt. Any recommendations & help would be appreciated and would help me make my family happier by not reaching or entangling themselves in any more wires than I already have. Thank you! |
| Building IR BEAM Break alarm system | damenace | Electronic Projects Design/Ideas/Reviews | 3 | 31st May 2008 08:44 PM |
| laser alarm system | ira thakur | Electronic Projects Design/Ideas/Reviews | 8 | 9th January 2008 02:11 AM |
| laser beam-break detector | Darth Bagel | Electronic Projects Design/Ideas/Reviews | 7 | 21st October 2007 04:18 AM |
| Laser Beam Tachometer With Pic | iftikhar ahmed | Micro Controllers | 7 | 10th February 2007 01:38 PM |
| Beam alarm system | zachtheterrible | Electronic Projects Design/Ideas/Reviews | 26 | 18th December 2004 09:26 PM |
