Old 24th January 2007, 03:17 AM   #91
Hit the igniter a few times with a good cap to buffer it and there may be a duel here!
straight answer, har har."
Sceadwian is offline
Old 31st January 2007, 10:21 PM   #92
Hi! I'm looking to build a shocker ( spark generator) for "decoration" purposes and not going out to shock a idiot. How long of a spark could be made using some of the circuits, etc. What are the schematics?
...and how would you calculate the distance of the spark?
Thank you
lcmvsv is offline
Old 1st February 2007, 02:50 AM   #93
I think a voltage of 10,000V will cause a spark of about 1cm long in fairly dry air.
A Telsa coil can make over 1million volts. You do the math to calculate the length of the spark.
audioguru is online now
Old 1st February 2007, 07:14 PM   #94
Oznog is offline
Old 1st February 2007, 08:46 PM   #95
woah, that's a high voltage to get such a little spark! so a 4cm spark would be 40,000V. k, so what transformers, capacitor, and relays could I use? plz not flyback :\
lcmvsv is offline
Old 1st February 2007, 09:19 PM   #96
A TV's flyback transformer operates at about 16kHz to produce 30,000V for a 32" colour TV. It has insulation to withstand such a high voltage.
An ordinary power transformer would produve a few hundred volts if it is used backwards.
An old audio transformer from a vacuum tube amplifier would produce maybe 600V if it is used backwards.
What else can make high voltages?
Old 2nd February 2007, 01:28 AM   #97
LOL at Oznog!!!! I was just talking about that gesture today at work. I wonder if it means the same thing to you. Please do tell what it means to you.
Sig239 is offline
Old 3rd February 2007, 01:44 PM   #98
Whee, high voltages.
A quick search on the internet and my brain turns these up:
Neon sign transformers (~5kV, a few mA)
Microwave oven transformers (~3kv, a few ma)
Oil burner ignitor transformers (beats me, I guess it's the same as MOTs)
Car ignition coils (dunno, but these things look cool. I've got one somewhere around...)
Van de graff generators (varies from a few kV to a million V, current miniscule)
Static
Those huge multiple storeys tall transmission towers just outside town. Yea, those...
The first 4 and last one are usually lethal, I guess.
And anyway, why not flybacks? Flybacks are the second easiest to get and build, with ignition coils the easiest.
Firnagzen is offline
Old 3rd February 2007, 02:28 PM   #99
Incorrect, 0.5A or more, enought to kill you for sure!
if I know the answer.
Hero999 is offline
Old 3rd February 2007, 04:18 PM   #100
Yes, microwave oven transformers are high voltage, high current - almost certainly fatal!.
Old 4th February 2007, 03:14 AM   #101
Technically they're rated for a few mA, I think, but since they have lousy current limiting, you can draw 0.5A out of it.
But whatever, a few mA or half an amp- You're STILL dead, it's only how toasty you get.
By the way, more on that, flybacks CAN be lethal too, look up ZVS driver for flybacks, those things can push more than 100W or so into a flyback.
Old 4th February 2007, 09:17 AM   #102
You think WRONG! - they are rated for continuous use at high current.
Old 4th February 2007, 09:28 AM   #103
I've been searching for a citcuit that can produce higher continuouse electricity from a battery.But this circuit can only produce a flash of elecricity.Do you have a circuit like that please?
Harry001 is offline
Old 4th February 2007, 10:14 AM   #104
No, a few mA and you'll probably live but half an amp and you're almost certainly dead.
Hero999 is offline
Old 4th February 2007, 06:26 PM   #105
Question help me
hi I'm looking to build a shocker ( spark generator) too
please send me a circuit and schematics compilitly
thanks
Thank you
mitra2640 is offline
project, shocker, simplest
