Old 22nd June 2006, 08:23 PM   #46
How about the tube?
Doesn't it have a built in HV capacitor?
I've heard stories about people being killed by carying TVs with the back of the TV facing thier chest then falling over and being electricuted by the stored charge.
if I know the answer.
Hero999 is offline
Old 22nd June 2006, 08:57 PM   #47
Originally Posted by Hero999
How about the tube?
Sort of!, the final anode inside the CRT, and the aquadag (the graphite paint on the back of the tube) form a capacitor, with the glass as the insulator.
I've heard stories about fairies and goblins! - what does a story have to do with anything?
The story is complete rubbish!.
However, it IS a damn good capacitor, I've known CRT's hold their charge for years! - but again, not enough energy to harm you.
Old 23rd June 2006, 09:16 AM   #48
Sounds like one for "Mythbusters" to me.
Not only is this the most awkward way to carry a TV, because the weight is all at the screen end due to the thick glass used in its construction.
A more likely end for someone falling over when carrying a TV this way would be by being speared by the neck of the tube.
But then again, most unlikely.
JimB is offline
Old 23rd June 2006, 03:06 PM   #49
Obviously you read but not understand. Did i forget to mention the limiting resistor without that adios. Can you understand that some of these people are not up to undesrstand the fatality of a TV transformer without current limiting, and might try to get the final buzz.
raybo is offline
Old 23rd June 2006, 06:30 PM   #50
What does adios mean?
Hero999 is offline
Old 24th June 2006, 05:16 PM   #51
tjhe same thing as astsa lavista and no problemo came from get an education will yah.
AND yes i got shock from a TV 4 years after storage myths only for newbies.
raybo is offline
Old 24th June 2006, 05:27 PM   #52
By the way when you quote someone you should put your reply below the quote not above.
Hero999 is offline
Old 24th June 2006, 06:12 PM   #53
As you are trying to teach us something, please get it right.
Adios = Spanish for Goodbye
Hasta la vista, baby = Spoken by Arnie Schwartzenegger in Terminator2 before he blew away the "bad cyborg".
My nightschool Spanish teacher (from Spain) was rather horrified by the expression as a corruption of the Spanish language!
Hasta luego = see you later.
No problemo = sounds a bit like Bart Simpson to me.
JimB is offline
Old 25th June 2006, 01:15 AM   #54
My 1970 TV had a regulated 25kV supply. I never felt a shock from it but during a shock it would simply increase the current to jolt you good.
audioguru is offline
Old 25th June 2006, 08:50 AM   #55
Regulated YES, high current NO - presuming you mean the crude valve sets?, they commonly used a shunt regulator to help stabilise the EHT (a PD500 valve was used in Europe for the job), but the current available was still very low.
What were dangerous were the far older B/W sets (before my time) that used mains transformers to genetate the EHT
Old 25th June 2006, 02:47 PM   #56
My old 'scope uses its mains transformer to make 1.5kVAC which is rectified and filtered into about 2kVDC.
I wonder which hurts more:
Electrons slamming into your skin in an arc, or
Holes leaving your skin in an arc.
I think the electrons would burn you.
Old 25th June 2006, 03:31 PM   #57
The contact point of an electric shock is a burn, and prolonged high current produces a deeper burn and 'cooking' of the flesh!.
Microwave ovens are probably by far the most dangerous thing in your house, 3KV DC at high current - death?, almost certainly!. So don't play with microwave ovens!.
Old 25th June 2006, 06:33 PM   #58
hi everybody , i've a little experience about electronics ,
May I introduce some projects which I was finished ??
visit this link
http://pg.photos.yahoo.com/ph/giaosu...765scd&.src=ph
E-DESIGN prestigious and quality
contact me:giaosucan2000@yahoo.com
giaosucan is offline
Old 25th June 2006, 08:13 PM   #59
Ummmm..What dose this have to do whith shocking and high voltage?
Oh and getting a arc to you from the flyback is not very good.the curent is not painful but then the real pain begins when the burnt skin starts hurting.I did it by getting to close to a wire.I stupidly used normal wire that can no where near stand the +10kV got to close and i fould feal a tickle and then the insulation arced trough and zap.The flyback was runing on a 555 timer and mosfet driver it has lots of power(Had flyback secundary heating problems).It left a small gry spot on my finger that itches very anoyingy for like a weak.So use wire wich has its insulation rated for high votage.Or you will end up whith a burnt finger like me.
Yea microwaves are proboby the most deadly apliance.More then 2kV at about 1 Amp (When secundary shorted can trip the circuit breaker)
Il give you shocking experience.
Someone Electro is offline
Old 26th June 2006, 10:21 PM   #60
I remember having an argument with the service manager of our TV servicing department because he wanted customers to change the bulbs in their microwaves themselves rather than sending an engineer out to do it. This involved removing the cover and exposing the entire innards of the microwave on the models we were doing. He simply wouldn't believe me that it was completely irresponsible to suggest such a thing, I think he thought I was exaggerating when I explained that one touch of those huge capacitors would almost certainly mean death.
Brian
ThermalRunaway is offline
project, shocker, simplest
