| Electronic Projects A collection of small electronic circuits and projects you can build. |
Here is something that I was able to build, it basically takes the pulse from a 555 timer and goes through a 7490 divide by 10 into a 7448 and finally into a LN514rk Common Cathode LED-- if you are going to use a common anode LED just replace the 7448 with a 7447 Materials Needed
Simply connect it as it is in the diagram http://www.quantumninja.com/hw/elec/circuitdone.jpg
__________________ Physics-Electronics- | |
The names royd! (well nickname and DJ name actually). I want to thank you for the 7 seg counter diagram, you say your a novice but beleive me they named the word novice in electronics after ME!!!" Im very willing and try hard to learn, i have a room full to the brim of parts from the past two years of pure guess work. Nothing ever really comes to light though, i wouldnt say im thick but it aint easy is it, i usually av a go mess it up, spend three days trying to figure what went wrong, then get seriously frustrated and end up sticking the girl freind in the fridge (joke). I really want to get results though as ive plenty of good ideas mainly security projects that could make money. plenty of idea's, none or little build knowlage, always the way hey? Any way your project doesnt look to bad so im going to have a crack at it, best go church first pray a bit. I will let you no how ive done, and please if you want to help me in any way with electronics ide be dambed gratefull. E-mail me anytime roydpro@yahoo.co.uk thanks again royd out... | |
hey i duno why u have used 200 ohms Resistance with Diode in 555 timer & same in 7490 ? Well would u like to answer me or can u explain da ciruit in more detial thanks waiting for reply Azam Jiva | |
Situation: I have 3 7-segment display and i want it to display numers form 0-999. The Problem : Using a 7447 i can display from 0-9,A,B,C,D,E,F in one of the 7-segment display. But how can i connect the 3 7-segment display in order to display from 0-999 | |
Hi jnkevin, Refer to my attachment below. For each individual digit, you need a counter, driver and 7-segment LED. To count beyond one digit, simply connect pin 11 of each 7490 to pin 14 of the next 7490. AllVol Last edited by AllVol; 6th February 2007 at 01:49 AM. | |
| | #6 |
This is a reat circuit, how would i go about controling 2 7 segment leds that I could increase by pressing a button?
| | #7 |
Hi weilst Welcome to the forum and thanks for your question. In the circuit you mention, the 555 timer is being used as what we call an astable multivibrator, meaning that it generates one pulse (or count) in a regular pattern. To manually produce a pulse would simply involve replacing the 555 timer with a switch connected to pin 14 of the 7490. Each time you close the switch, the counter advances by one. However, a switch will open and close rapidly because of its mechanical nature, resulting in "switch bounce" which will cause false counts. There are a number of circuits you can use between the switch and pin 14 to eliminate switch bounce. Look up switch bounce on Google for circuits. Good luck, AllVol
__________________ Creationists have a world of evidence | |
| | #8 | |
Brian | ||
| | #9 |
Yep, that's right. I meant to add that, but was in a hurry and forgot. Thanks, Brian. Edit: However, following a closer reading of your comment, you indicate seperate gates are necessary for the clocking of the second counter. Incorrect. The second counter will be clocked directly by the first. See reply #6. Only if one wishes to reset after some number less than 9 would one need to use a logic gate. Allvol
__________________ Creationists have a world of evidence Last edited by AllVol; 15th July 2006 at 04:37 PM. | |
| | #10 |
See...this is the type of circuit that the groups need more of. Simple, good, clear instructions...not 2 many parts. Just look at the amount of interest this simple little circuit has stirred up. keep up the good work Kim | |
| | #11 |
Hey All Hi I Need Help Counter Asm Code
| | #12 |
pls send ckt. diagram for 7 segment up/down counter using simple i.c.'s and operate on 12 V dc my id is --- ejagdeep@gmail.com | |
| | #13 |
you have done very good job.but i confused at one point that where you have connected the diode's cathods in 7490 ic ckt.to ground or +5v.thanx
| | #14 |
thanks man
| | #15 |
| thanx mate! | |
| 7segment, base, binary, counter, led |
