| Notices |
| Electronic Projects A collection of small electronic circuits and projects you can build. |
| New Member | Quote:
,.plz,.it would be a great help guys,...thank's.,. e-mail; eiluj_872001@yahoo.com | |
| New Member | Hello! I'd need help/advice of what can be wrong in my pulse counter. It is based on 7490+7447+common anode 7-segment displays. There are 3 phases, i.e. it counts from 000 to 999. Generally everything's ok, but the pin 11 of the 7490's raise too often, about randomly. It should raise every 10th pulse, right? With oscilloscope I could see quick peaks in the 7490's Qx outputs. What can be wrong? I've checked many times the connections with magnification. |
| New Member | Here's the circuit. Pulses are generated from the LDR to the counter. Button is for reseting the display. I appreciate of comments. |
| Experienced Member | I don't see any bypass caps. You should have a capacitor (I like 0.1uF for 7400 series chips) from 5V to GND near every chip. 0V probably should be connected to gnd. The detector should have some hysteresis; see if a 7414 works better in place of the 7404. |
| Experienced Member | Yes a bypass cap is a def must with these counting chips.. when the number of LEDS which are on switches it can cause irratic behaviour..
__________________ "Stick around" - Arnold Schwarzenegger in The Predator after impaling a soldier to a wood post 9vDC Guitar Pedal PSU PIC16F84a Game Module |
| New Member | Thank you for replies! I'll do the modifications and tell you later how they work! Arto |
| New Member | is the materials available here |
| New Member | Here's the fixed circuit. In the previous circuit diagram I posted there is a drawing error: all the ground level voltages are connected into same potential. Only improvement was that the 74LS04 needed to be changed to 74LS14. Works!! The pulses from the transistor were not so clean, so the counter incremented too much (with 74LS04). This picture is of circuit that works. Last edited by ArtoR; 4th March 2008 at 07:21 PM. |
| Experienced Member | Geat but you could save an IC if you don't mine an extra transistor and a few resistors. |
| New Member | Quote:
can display 0-9 in 7-segment. bt how do i do the A-F part?????? does it require any extra chip or something?????? help plzzz. or i'll have 2 make sumthing to take carry bit frm 7483 and work on it.. | |
| Experienced Member | Try spell-check first, Sorry my poor English translator is not functioning properly..lol -BaC Quote:
__________________ Error: {Panic!} when trying to load: [reality shell]. kernel: "universe has been halted"... Information Underground | |
| New Member | to bacardi( sozzled, as the name suggests), u can learn ur english in ENGLISH CLASSES. try to help in the electronics part. Abuses apart, can someone send me the connection btwn a 7448 and 1050CHRI( common cathode 7-segment). |
| Experienced Member | Damned them id10t errors...lol
| New Member | Quote:
