Old 24th January 2008, 01:45 PM   #16
Smile
Originally Posted by Tom McCurdy
Here is something that I was able to build, it basically takes the pulse from a 555 timer and goes through a 7490 divide by 10 into a 7448 and finally into a LN514rk Common Cathode LED-- if you are going to use a common anode LED just replace the 7448 with a 7447
Materials Needed
  • 5 V-Source
    Wires
    555-Integrated Circuit
    7490-Integrated Circuit
    7448-Integrated Circuit
    7-Segment Display (the one I used was LN514RK)
Simply connect it as it is in the diagram
http://www.quantumninja.com/hw/elec/circuitdone.jpg
ei, can you send me a pcb design for this circuit,.using common anode,.,.
,.plz,.it would be a great help guys,...thank's.,.
e-mail;
eiluj_872001@yahoo.com
angst is offline
Old 21st February 2008, 09:55 PM   #17
Hello!
I'd need help/advice of what can be wrong in my pulse counter.
It is based on 7490+7447+common anode 7-segment displays.
There are 3 phases, i.e. it counts from 000 to 999.
Generally everything's ok, but the pin 11 of the 7490's raise too often,
about randomly. It should raise every 10th pulse, right?
With oscilloscope I could see quick peaks in the 7490's Qx outputs.
What can be wrong? I've checked many times the connections
with magnification.
ArtoR is offline
Old 21st February 2008, 10:00 PM   #18
Here's the circuit. Pulses are generated from the LDR to the counter.
Button is for reseting the display.
I appreciate of comments.
7-Segment LED Counter (binary and base 10)-ldr-darkness-activated-circuit.jpg
ArtoR is offline
Old 21st February 2008, 10:20 PM   #19
I don't see any bypass caps. You should have a capacitor (I like 0.1uF for 7400 series chips) from 5V to GND near every chip. 0V probably should be connected to gnd.
The detector should have some hysteresis; see if a 7414 works better in place of the 7404.
mneary is offline
Old 22nd February 2008, 04:31 AM   #20
Yes a bypass cap is a def must with these counting chips.. when the number of LEDS which are on switches it can cause irratic behaviour..
"Stick around" - Arnold Schwarzenegger in The Predator after impaling a soldier to a wood post
9vDC Guitar Pedal PSU
PIC16F84a Game Module
Peter_wadley is offline
Old 25th February 2008, 04:17 PM   #21
Thank you for replies!
I'll do the modifications and tell you later how they work!
Arto
ArtoR is offline
Old 27th February 2008, 04:05 AM   #22
is the materials available here
lanz is offline
Old 4th March 2008, 08:18 PM   #23
Here's the fixed circuit.
In the previous circuit diagram I posted there is a drawing error: all the ground level voltages are connected into same potential.
Only improvement was that the 74LS04 needed to be changed to 74LS14.
Works!!
The pulses from the transistor were not so clean, so the counter incremented too much (with 74LS04).
This picture is of circuit that works.
ArtoR is offline
Old 5th March 2008, 12:37 PM   #24
Geat but you could save an IC if you don't mine an extra transistor and a few resistors.
if I know the answer.
Hero999 is offline
Old 23rd May 2008, 11:05 AM   #25
Originally Posted by jnkevin View Post
Situation:
I have 3 7-segment display and i want it to display numers form 0-999.
The Problem :
Using a 7447 i can display from 0-9,A,B,C,D,E,F in one of the 7-segment display.
But how can i connect the 3 7-segment display in order to display from 0-999
m a high scl guy...m making a decimal adder circuit.....already done adddition part using 7483.
can display 0-9 in 7-segment. bt how do i do the A-F part??????
does it require any extra chip or something??????
help plzzz.
or i'll have 2 make sumthing to take carry bit frm 7483 and work on it..
TechnotroANIK is offline
Old 24th May 2008, 06:53 AM   #26
Try spell-check first, Sorry my poor English translator is not functioning properly..lol
-BaC
help plzzz.
Error[888] "while trying to load":[reality.sh] kernel: [Panic!]...{Universe has been Modified!}...
BaCaRdi is offline
Old 24th May 2008, 08:57 AM   #27
to bacardi( sozzled, as the name suggests),
u can learn ur english in ENGLISH CLASSES.
try to help in the electronics part.
Abuses apart,
can someone send me the connection btwn a 7448 and 1050CHRI( common cathode 7-segment).
Old 24th May 2008, 09:15 AM   #28
Damned them id10t errors...lol
Abuses apart,
BaCaRdi is offline
Old 26th May 2008, 12:46 PM   #29
Originally Posted by ThermalRunaway View Post
In order to control two 7 segment displays using a circuit similar to the one above, you'd need two binary counters and two display drivers. The second binary counter would need to be clocked by the overflow of the first using some simple logic gates.
Brian
do you have the circuit...? so i could know the configurations..thanx
kevlar_star is offline
Old 19th July 2008, 02:22 PM   #30
hello... i need a 4 seven segment display counter from 0 to 9999 that has an ANY value of DC supply. will you please help me how to do that???
if u have a circuit diagram for it... email me at john_rey12@yahoo.com
thanks..
NaRuTo is offline
7segment, base, binary, counter, led
