Closed Thread
Page 1 of 4
1 2 3 4 Last
Results 1 to 15 of 48
Thread: spark without battries
  1. #1
    ardnat Newbie
    Join Date
    Nov 2004
    Posts
    10
    Default spark without battries
    open a fire tourch, you should find something like A RECTANGLE swich with to contacts on one side. this is a pizo it makes over 1kvdc so just mount it soder two wires and make a gap press the bution spark!
    (ill post pictures in a cuple days) :lol:
  2. #2
    ardnat Newbie
    Join Date
    Nov 2004
    Posts
    10
    pic
  3. #3
    ardnat Newbie
    Join Date
    Nov 2004
    Posts
    10
    pic
  4. #4
    ardnat Newbie
    Join Date
    Nov 2004
    Posts
    10
    sory have bad camra
  5. #5
    ardnat Newbie
    Join Date
    Nov 2004
    Posts
    10
    the spark is about 1/2 of an inch
  6. #6
    Klaus Newbie
    Join Date
    May 2003
    Location
    Australia
    Posts
    557
    Its not your camera, its just that sparks are a *very* brief affair and rather difficult to catch with a camera. Though you could have tried to get whatever makes the spark into focus (you might have to use the macro setting)
    Klaus
  7. #7
    FoxyRick Newbie
    Join Date
    Nov 2004
    Posts
    19
    At the school I teach at, the kids like to take these igniters out of lighters etc. They use them to shock their 'friends' in class - great fun!
    FoxyRick.
  8. #8
    Someone Electro Newbie
    Join Date
    Sep 2003
    Location
    A boring village in Europe (slovene)
    Posts
    2,601
    I know there good for pranks.
    They are caled "piezo ignitors"
    they give about 10 000 V but since it very low curent they only itch
    Il give you shocking experience.
  9. #9
    Dr.EM Newbie
    Join Date
    Oct 2004
    Location
    UK
    Posts
    1,014
    Ah yes, i've seen these things before. Never knew they were piezo though.
    Angry!? I'm absolutely electrolytic!
    Music web page:
    http://www.music-playground.net/artist/drem/
  10. #10
    Join Date
    Sep 2003
    Location
    Posts
    2,601
    You can try to conat an piezo speker to you multimeter (mV reding) and push it together whith your fingers.
    The harder you sqize it the more voltege it produses
    but i never tryed to make sound whith an piezo lighter
  11. #11
    zachtheterrible Newbie
    Join Date
    May 2004
    Location
    California, USA
    Posts
    2,160
    hee hee, great fun :lol: took it to skool and had me a good lauf.
    a fun thing thing to do is put the wire on your neck in certain spots, teh whole side of ur body jumps.
    electro, u sed that u need two wires for the spark to arc across? i just had one wire sticking out of mine and all i had to do was touch it to someone's skin (or get close enuf)
  12. #12
    Join Date
    Sep 2003
    Location
    Posts
    2,601
    It has only one wire.Thats one pole,the other pole is the metal cilinder on the botom
    But electrycety arcs to someone else becose the body has capacitence (100-200 pF) and becose there is a ground conectin to you and your toching toching the cilinder (other pole)
    I once used my body as an cap in an 555 timer circuit.Ti was fun (i just codn't stop playing whith it) the harde you sued your finger on the contacks the lower was the beep coming out of the spaker(try it sometimes)
    Ive seen a circuit that uses an piezo lighter whitn an weight on top as an seizmic detector (to detect erthquakes)
    I like my "simplest shocker"(in the projects) but for pranks you beter put an resistor in (it can be painful)
  13. #13
    moody07747 Newbie
    Join Date
    May 2005
    Location
    NJ
    Posts
    550
    let me help you out with that pic :lol:
    heres what looks like the same one you have there
    here are many different type of these
    some have 1 wire and a brass stud at the bottom
    and others have 2 metal spots
    the ones with the 2 tabs are easy to wire and put in a small project box
    i normally attach the outputs to two thumb tacks
    (like these)
    http://www.flashfire.com/wirrndrs/Tack1.jpg
    just stick them into a case and bend the point over so it does not come out of the case.
    be sure to put them about 1" apart so the spark wont jump the gap
    Dave
    www.myspace.com/sonicorbstudios
    Welcome to "Sonic Orb Studios"
  14. #14
    tikbalang Newbie
    Join Date
    Sep 2005
    Posts
    8
    is there a way to harness the electrical charge from piezo igniters? like, for charging nicads.
  15. #15
    Join Date
    Sep 2003
    Location
    Posts
    2,601
    You codnt get an good charge out of this.SInce thay outout high voltages at very low curents.
Closed Thread
Page 1 of 4
1 2 3 4 Last
Tags for this Thread
