| | #31 |
Its probobly metal in the air. I know that ozone smells much fresher.
| | #32 |
If you want a little bit more substantial spark, you can use a barbecue grill ignitor. You can buy replacements from a hardware store usually, or get one online. Should be around $5 or so. The sparks can be about 1 inch long if I remember correctly, and are good for making potato cannons. They all look about the same: long plastic housing, red button with black bezel. It uses the same piezo technology in a butane lighter, only on a bigger scale, and the force required to press the button is a bit more. Attached is a pic example. | |
| | #33 | |
| | #34 |
lol i find that one funny...these little sparkers are harmless....not nearly anything deadly in them
| | #35 |
Unles your in a room full of gasoline vapor.
| | #36 | |
Actually, nothing happens unless the air to gasoline ratio is about 14.5. If the mixture is too rich or is too lean then it won't burn.
| | #37 |
stoichiometric ratio for air to gasoline is actually 14.7 :wink: But yeah, 14.5 is definitely close enough. | |
| | #38 |
How your piezo works: ![]() On the right there's a piece of piexo crystal connected to the electrodes. On the left there's a spring with a pin and a catch mechinism attached to the button. When you push the button the spring compresses first, then when it's fully depressed the catch releases firing the pin at the piezo crystal and all the mechanical energy is converted into a pulse of electrical energy powerfull enough to ignite gas and even kill some insects but too small to harm you.
| | #39 |
Killl a instect? Never tryed that.
| | #40 | |
__________________ /////////// if i have knowledge///////////// share (it) thats my code im the website king!!!!!!!!!!!!!!!!!!! | ||
| | #41 | |
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #42 | |
__________________ My Property and my Family are not for Govenments to control.That is not the purpose of Governments. To stop corruption in Government officials give them three times the penalty. They should, and do, know better. Let them commit to that when first employed | ||
| | #43 | |
| | #44 |
Most insects die when frozen because ice crystals from in their blood. Interestingly some insects are active during the winter in the UK despite the fact it can get very cold, I wonder how they cope with it.
| | #45 | |
__________________ Don't make me reach through this monitor to slap you a good one! | ||
| battries, spark |
