Old 31st August 2007, 09:20 PM   #31
Look up FM on Wikipedia.
if I know the answer.
Hero999 is offline
Old 15th September 2007, 07:45 AM   #32
Default hello
Originally Posted by audioguru
Mine has a power amp stage and goes very far:
its that really working and what bout the range of that fm transmitter? an you explain the circuit to me.. so that i can understand thanks
AND
AND_ECE is offline
Old 19th September 2007, 01:19 AM   #33
My FM transmitter has an RF amplifier on its output.
With a new 9V alkaline battery its range is more than 2km across a large river valley to my very sensitive home FM tuner and to my very sensitive car radio.
The range is about 300m to my Sony Walkman radio.
Hills, buildings and trees block the signal.
audioguru is offline
Old 20th September 2007, 08:52 PM   #34
I think I heard your broadcast of Gordon Lightfoot's song, The Edmund Fitzgerald. The transmission must have rode in on one of those Great Lakes gales that begin this time of year!!
BTW, sometime I want to discuss these Alberta Clippers that you folks send our way. That stuff has got to stop or we start sending you illegal Mexicans .... (and we have enough of them to cripple your economy!
HiTech is offline
Old 20th September 2007, 09:06 PM   #35
Canada gets its share of illegal foreigners. They do the "dirty" work that local people don't want to do. Boatloads arrive from China each year.
Old 30th October 2007, 09:31 AM   #36
Does anyone have a circuit of a simple low power FM transmitter that uses crystal 1MHz and has a 105Mhz output? dont know how that is done but if anyone can help??
TinaiKevin is offline
Old 30th October 2007, 11:01 AM   #37
Trouble is it wouldn't be simple!.
Old 30th October 2007, 11:31 AM   #38
Default FM transmitter
You are right about it being not simple! Is there any other alternative to the programmable chip, by using dividers/multipliers(that are set) or flipflops. I am not that well versed with all programmable stuff.
Old 30th October 2007, 12:03 PM   #39
No, from a 1MHz crystal you have to use a PLL system, you couldn't even use multipliers - which would be complicated anyway.
Old 30th October 2007, 02:49 PM   #40
If you can use 15MHz crystal as oscillator and derive the 7th harmonic, perhps you may end up getting the required 105MHz. Mostly a single 74HCU04 and few pf caps and an inductor are all that are needed. It could work off 5Vsupply. A sample diagram is attached , thanks to G Baars the designer of SW radio capture.
Regards,
Sarma.
mvs sarma is online now
Old 30th October 2007, 04:25 PM   #41
There is a similar FM transmitter that uses a 10.7Mhz crystal filter from the IF of an FM radio as its oscillator. Then Cmos inverters clip it into aquare-waves and its output at the 9th harmonic is at 96.3MHz.
I don't think an ordinary CD4069 inverter works at a frequency as high as 10.7MHz. Maybe a 74HC04 is needed with a 5V supply.
Old 30th October 2007, 05:41 PM   #42
I fear there is no filter that would select 9th harmonic, as such, we cant, say it would not interfere at many other frequencies.-- in the FM band
it will be seen as 9th harmonic -may be. the actualtransmitted energu may be perhaps 10.& only.
as 4069 is working with a 9V supply, it might cover upto 10 or 12 MHz
Regards,
Sarma.
Old 30th October 2007, 07:11 PM   #43
It has a square-wave output so its even harmonics are low.
It has very low output power so it won't cause much interference.
Its higher harmonics are low level and might be on a TV channel's frequency.
Its 7th harmonic at 74.9MHz is not in the FM band but might be a TV channel in some countries.
Old 13th November 2007, 11:58 PM   #44
Are those transmitters the same as the ones located in rc stuff like cars and stuff? Could anyone tell me the requirments to make one of these that can control motors for at least 20 ft?
GreenAce92 is offline
Old 14th November 2007, 12:53 AM   #45
These are wideband FM transmitters for the FM broadcast band.
Cheap RC transmitters are just a single transistor that has AM modulation and a single transistor "radio receiver" that is a super-regen receiver.
Good RC transmitters and receivers use a quartz crystal for frequency accuracy and many transistors and ICs for digital FM.
simple, transmitters
