There are so many schematics out there for the different usages of the 555 and alot of terminology for each circuit that i don't know. I was hoping someone could point me in the right direction for a specific usage. What i want to do is to build a circuit that will turn power on to a 4v motor for a variable time frame ( maybe a pot adjustment) then turn off for a adjustable time frame the same way. I have a solar tracker that does this. Thanks | |
How long on, how long off? Do you want to switch the motor positive wire or the motor negative wire?
__________________ Mike ML. | |
I probably will switch the positive pole. (Unless it's easier to do the negative, the motor is bi-polar) As for the time frames. i'm not quite sure, hence the variable portion. Until i build your 12v to 4v step down circuit i won't know the timing span. Do i have to set it without variables? I was hoping that i could incorporate pots to vary the time on/off.
Ok but you have to have some idea. Is it weeks, days, hours, minutes, or seconds????
__________________ Mike ML. Last edited by MikeMl; 11th November 2009 at 04:24 PM. | |
oh, The on time should be around 15 seconds, and the off time would be 30 minutes.
| | #6 |
30 min is too long for a 555. Now it gets more complicated
| | #7 |
how about 2 second for 1 minute?
| | #8 |
What i'm trying to accomplish is 24 revolutions per day. That is the perfect setting however i can accomplish that will suit my needs perfectly.
| | #9 |
| That is better for a 555. What is the supply voltage (not the motor voltage), but the actual power supply you want to run this on)? I have an idea on how to incorporate the motor voltage reducer at the same time.
| | #10 | |
Dont you really want a 1/2 revolution each time? How do you get exactly one/half revolution? Do you have a limit switch or indexing switch?
__________________ Mike ML. | ||
| | #11 |
i will post in a minute i have to add a picture to this to better explain the motor setup.
| | #12 |
Ok as it is, the motor at 12v rotates 1 time every 15 seconds @ 4v is rotates 1 round per 45 seconds. As for the supply power 120v would save me the room on the pcb but 12v supply will suffice. I have more transformers to use, just limited space. | |
| | #13 |
Ok, now I am totally confused. Do you care where the motor arm stops, or do just want to move a random amount each time you move it? How far does the motor turn each time the 555 timer's output is ON?
| | #14 |
It doesn't matter which position that it stops each time it just has to make 1 full revolution total 24 times a day. So it could move for 1 or 2 seconds then stop for max time. then repeat. the arm makes full rotations. i don't have limit switches on the arm.
| | #15 |
rotating 24 times a day would be perfect but it can make more rotations if it has to. Just as little as possible.
| 555, chip, information |
| 555 timer chip with servo | lukus555 | Electronic Projects Design/Ideas/Reviews | 11 | 11th November 2008 04:56 PM |
| Modern chip Hardcore ASM information. | Sceadwian | General Electronics Chat | 3 | 21st September 2008 12:32 AM |
| Want to find more information on Baseband chip | lowkb | General Electronics Chat | 1 | 12th May 2006 03:54 PM |
| Information about an IC chip | Electrostatic | Datasheet/Parts Requests | 1 | 27th November 2005 09:36 AM |
| 40110 chip information | geoff2004 | General Electronics Chat | 5 | 24th February 2004 03:14 AM |
