New to the forums, so howdy yall. Being an avid PC flight sim enthusiast, a somewhat technically inclined person, and with some electronics training MANY years ago in radio and television repair (tube type TVs). I have only recently decided to try something I have been wanting to try for a while. My HOTAS system, a Saitek X45, has recently started malfunctioning. I know what the problem is, a cable with some worn wires that goes between the throttle and stick. I could go out and buy a DB15 d-sub gameport connector, cut the cable and make the repair. But I am also one of those "While I have it taken apart I may as well try to make it better " types. , yeah, like there arent any of those around here.Anyway, I have been watching for a while, other people custominzing controllers, and even building VERY elaborate simpits. I have neither the time, or resources, or really even the desire to undertake some of the more elaborate things I have seen, I do suffer from the "While I have it apart .... " thing. Here is my idea, problem, project, delima. For a little more clarity, I am including an image/ schematic of the internals of the electronics inside the throttle. ![]() The connections out the top more or less head out to the stick portion of the HOTAS. The connections along the bottom are to be connected to a micro- controller sold on the internet for use in other projects. I wont be using that device. One more piece of info before I get to my question. I have been using custom drivers for the device, with a scripting language to make and load specific profiles. Now with the scripts, I am able to use the mode switch, which is a single device, a 3 positions switch, to make every button, switch, POV hat, and axis, perform completely different functions in each of the 3 modes (designated as mode 1- mode 2- mode 3 in the image). What I am wanting to do, is to build a board (panel ) and divide it into 3 different zones. I will call the NAV, AA, and AG. I want to, instead of having one button do three different things, I want to have 3 different physical buttons, one in each zone, and then have it set up so that when I change the mode switch, it will move the connections or active buttons to one of the 3 different zones. I am doubtful that the small mode switch will be sufficient enough to do this all by itself, but rewiring a bigger stronger switch in its place in the circuit is not a problem. I do know how I could do it mechanically by physically wiring all the different mode zones and using a mechanincal device, but it would end up a rather large, unwieldly and crude device. I thought that I might be able to do it with a set of relays and and some sort of solenoids to make a mechanical/ electrical switching device as well. Then I thought, that there are a lot of more experienced, and smarter people than me out there. (HERE) Can anyone think of a way, that I could divert the signal, data, current from one zone of the 3 to another, using electronics ? One last note, I dont have to have all of the buttons, switches, axis moved. Although that would be nice, but any help or ideas to help me get started would be much appreciated. I would fall back on my TV repair training, but for the love of me I cant think of any way to get vaccume tubes to do this. ![]() Sorry for the length of this, especially since I am not sure that I have been completely clear. Hopefully someone will understand, and be one of those smarter and more experienced types I already mentioned. Thank you. Last edited by kmcwilliams; 11th November 2009 at 06:18 AM. | |
Is this running on FSBUS?? Do you mean like one of these... | |
| electronically |
| Electronically Impulsing a pendulum for a clock | markelectro | General Electronics Chat | 90 | 4th May 2008 04:40 PM |
| swapping polarity electronically | atf1084 | Electronic Projects Design/Ideas/Reviews | 10 | 6th January 2008 12:18 PM |
| Electronically activated switch | troy310589 | Electronic Projects Design/Ideas/Reviews | 8 | 2nd July 2006 11:29 AM |
| how can i measure vaccum electronically? | max_imum2000 | General Electronics Chat | 9 | 14th May 2006 07:07 PM |
| Is this (electronically) legal? | mstechca | Electronic Projects Design/Ideas/Reviews | 14 | 17th April 2006 08:00 AM |
