Old 11th November 2009, 12:40 AM   #1
Post a few diodes,if you please
need to understand how a diode (current limit?)..I have seen in some older
gear,..a diode glowing,...not an LED,...thought maybe being driven in inverse?...
thanx
NATY is offline
Old 11th November 2009, 05:39 PM   #2
It probably wasn't a diode but a neon lamp if it was for current limiting? Aren't neon lamps used for that at times, or were?
smanches is offline
Old 11th November 2009, 06:19 PM   #3
I've seen some LEDs like that. They look like an ordinary small signal diode, similar in style to a 1N4148, but are actually LEDs. They were being used as status LEDs on a PCB to aid in trouble shooting.
kchriste is offline
Old 11th November 2009, 07:03 PM   #4
A neon lamp can be used to generate a constant voltage but not current. The only two terminal devices that are current limiting are some called constant-current diodes, but they usually consist of a JFET with the gate connected to the source to provide the constant current function.
Carl
Curmudgeon Elektroniker
crutschow is online now
Old 16th November 2009, 05:53 PM   #5
no,...I don't think so...
the diode appears in a clock circuit,near a large cap,...does not appear
as a neon,....(flickering...),...but as a constant glow (red)...equipment is an
older JVC stereo VHS....
and thanx for the replies..
NATY is offline
Old 16th November 2009, 06:24 PM   #6
A neon lamp will normally give off a constant orange glow (which can look red with a red filter). They usually only flicker when they get old, after many hours of operation.
Carl
Old 17th November 2009, 01:39 AM   #7
Just before everybody tries to solve a riddle how about two photos?
(one with the device glowing and one off)
A picture says more than thousand words.
Boncuk
Boncuk is online now
Old 17th November 2009, 07:07 PM   #8
have yet to post either pics schm,..or other
do not have camera for my beast here..
that's why I tried to present my delema as I did..
also, while wr're it it,..could anyone provide a sch for keyboard or pad
endcoder...and an example of hard-wired diode mem?
thanx again..
NATY is offline
Old 17th November 2009, 09:32 PM   #9
It's probably a status LED used for troubleshooting. If it's near a large cap, that could be part of the power supply circuit, maybe an indicator that the power is on.
If it looks like a diode but it glows, it's an LED in a diode-type housing. I too have seen these on some older boards, as status or troubleshooting indicators.
kpatz is offline
Old 17th November 2009, 09:46 PM   #10
Many years ago they made current-limiting "diodes" (that had two leads like a diode) from a Jfet with its gate connected to its source.
audioguru is online now
diodes
diodes j taylor General Electronics Chat 4 14th December 2008 08:55 PM
Diodes joshua17ss2 Datasheet/Parts Requests 4 25th April 2008 03:47 AM
Diodes hykwei General Electronics Chat 9 25th February 2008 05:26 PM
Will a rectifier diodes work as protection diodes in a relay app? Andy1845c General Electronics Chat 12 15th November 2007 10:42 PM
zener diodes & rectifier diodes mozikluv Datasheet/Parts Requests 2 16th September 2003 06:17 AM
