Old 11th July 2004, 06:52 AM   (permalink)
Default Nice
Thanks a lot, I want to try this very soon.
Clyd3 is offline
Old 11th July 2004, 06:56 AM   (permalink)
You cod try making a coil of wire thin wire and conecting a low curent led to it.Stick it to a phone and try to make a call.
Il give you shocking experience.
Someone Electro is offline
Old 11th July 2004, 07:23 AM   (permalink)
I could find LEDs which work @ 2mA. I guess this would be sufficient. I buy one and do as you said.
rahul986 is offline
Old 11th July 2004, 02:04 PM   (permalink)
What size coil would you be using, are you talking about using hundreds of turns or just a few?
vaineo is offline
Old 11th July 2004, 03:01 PM   (permalink)
I think 30 thurns shod do.Here the biger the beter is NOT true.Becose if you use a to big coil it will have an to high inductace wich will mean it codnt pick up the high freq. radio signal so well.So if you try to make a realy big coil you have to keep the inductace of ti to the minimum.
Try eksperemantig whith the coil!
Old 12th July 2004, 03:38 PM   (permalink)
Nope. I tried that but in vain. The LED just didn't glow. I used 40 turns of coil around a 1cm diameter material. If anyone of you got it right can you post the circuit so that I can cross check with mine. Anyway before I get a reply, I'll try out the circuit in my college's electronics lab.
rahul986 is offline
Old 12th July 2004, 05:05 PM   (permalink)
I would suspect you need the coil tuned to the output frequency of the phone, this is likely to be very little of a coil at all for the frequencies involved.
Old 13th July 2004, 04:47 AM   (permalink)
I gues the iron core you used gave it to much inductance(The signal broke it self).You shod try whith air core and a flat coil.Or meaby 40 thurns is to much.As i sead eksperement. (Try difrent tipes of coil,difrent number of thurns,difrent wire...)
Old 13th July 2004, 04:01 PM   (permalink)
Hmm. I'll try that. May be i'll need some time for that. Before that if anyone gets some other idea please post it
rahul986 is offline
Old 13th July 2004, 04:22 PM   (permalink)
there are quite a few 'mobile phone trackers' circuit diag around on the net, maybe that would give you some hints as to frequencies etc.
i seem to remember that a mobile phone signal (unless decoded) 'pulses' - maybe this would be some use in getting the LEDs to flash...
just my thoughts
Tim
grrr_arrghh is offline
