Hi I need help for building a small circuit to drive a 18 LED strip to be used as a 3rd Brake Light in my car (12V), that emulates the ones from F1 cars used in raining race. LEDs should light in the following way: I think I can use a 555 but the burst rate will be a problem...any ideas? Thanks! PS: Data from the LED strip is here: SMD 3528 Flexible LED Light Strip 300 LEDs | |
You could use a PIC microcontroller, with an output driver stage. The possible combinations, sequences etc are only limited by your imagination Jim | |
FYI, this kind of light on a street vehicle will almost certainly be illegal in any state I know of.
| | #6 |
| Well, then there is a very easy method to get a flashing red light followed by a solid red: You use two 555 timers which are OR connected to the gate of the FET that drives the brake light or LED. In other words, either 555 can turn it on. Set up one 555 as a free running astabe at some pulse frequency and set the other up as a one shot with an inverter so it drives the LED on solid after the time duration elapses. When you apply power, the astable will pulse the LED. After the other 555 times out, it turns it on steady. I built this for my motorcycle a while back (which is how I found out they are illegal here). I don't know any easy way to get two different flash rates in a row followed by a solid red. Last edited by bountyhunter; 8th November 2009 at 01:21 AM. | |
| | #7 | |
Thanks!!! | ||
| | #8 |
Another option for pulse-than-steady, like bountyhunter's, is one I made many years ago. Just in my head...two oscillators + two delay circuits + AND or OR gates. The first two parts are easy, but the logic in the third part will take some thinking. Actually, now I'd opt for a cheap and easy 8-pin µController like a PICAXE. ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| | #9 | |
| 3rd, brake, led, light, style |
| Car LED tail/brake light project | TuscanT | Electronic Projects Design/Ideas/Reviews | 40 | 17th December 2007 10:41 PM |
| LED brake light/blinker ideas | buzzardman | Electronic Projects Design/Ideas/Reviews | 49 | 31st October 2007 08:12 AM |
| Need Help Designing LED Tail/Brake Light | ledsales | Electronic Projects Design/Ideas/Reviews | 28 | 23rd May 2007 07:40 AM |
| MC Brake Light - Circuit Help Needed | I-See | Electronic Projects Design/Ideas/Reviews | 4 | 16th February 2007 03:28 AM |
| brake light/ turn signal | andrew8485 | Electronic Projects Design/Ideas/Reviews | 13 | 11th November 2003 01:49 AM |
