Old 7th November 2009, 05:19 AM   #1
Default Simple short range IR/laser beam break position detector
Hi
Trying to get ideas on setting up a short range (500mm max) beam that if interrupted provides a trigger of sorts.
The range needed is short but accuracy or "width" of beam should be a mm or so at most.
I am hoping to not use a reflector at the "receiving" end of the beam. Is this possible?
IOW, a beam generator that would generate a 1mm round beam for 500mm that if broken by an object will provide a trigger.
croak is offline
beam, break, detector, ir or laser, position, range, short, simple
IR beam break detector MikeMl General Electronics Chat 12 11th September 2009 09:00 AM
laser beam-break detector Darth Bagel Electronic Projects Design/Ideas/Reviews 9 15th November 2008 04:33 AM
I want to make a short range tracking device , small size, and see 3D position on PC prabhatkr Electronic Projects Design/Ideas/Reviews 8 11th December 2007 03:35 PM
infared break beam detector from forrest mims green book maverick8888 Electronic Projects Design/Ideas/Reviews 14 30th July 2004 08:34 AM
Does this work? Laser break beam sensor and delay timer RuaRi Electronic Projects Design/Ideas/Reviews 5 6th May 2004 05:40 PM
