Hi all I know this is a long post but I tried to put everthing... I am making a bridge rectifier to give DC voltage to another circuit. At the output of the rectifier I am connecting 0.47uF-250V, mylar capacitor and across the capacitor I am connecting resistive load. The bridge should rectify 120 VAC from a WALL OUTLET to obtain a DC voltage. I am trying to acheive as close as possible to 170 VDC. Now the problem is that I want to get this voltage with respect to circuit ground. What happens is if I try to connect other end of the capacitor to ground some diodes blow off. Even if I try to connect oscilloscope between two terminal of capacitor some diode blows off. I searched it over the net and found out similar post: http://www.electro-tech-online.com/e...r-problem.html I think I am also facing the similar problem. Could anyone please tell me why this is happening? Why the other end of the capacitor is not always at potential 0V? What should I do now to get a 170V DC power supply? I mesure the voltages at both ends of the capcaitor by just connecting positive terminal of a 10X probe to the circuit and floating the probe's ground. And I saw that capactor terminal that I think should be at 0V is actually oscillating between 0V and -170V. At the same time other end of the capacitor is oscillating between 170V and 0V. Hence together they will give me 170VDC. But how to connect them to another circuit? Kindly provide some inputs I am so confused. Thank you. Sincerely Richeek Arya | |
As neutral is connected to ground you can't connect the output of the bridge to ground, it will go BANG!!! as you've found out. To do it with a bridge would require an isolating transformer, which sounds a good idea anyway. | |
Is it not neutral connected to ground? I have the notion that neutral is connected to ground in domestic power supply.
Look at the schematic for a bridge rectifier. The common of the bridge is not connected to the common of the source. If you connect the common of the bridge to the common of the source, then you will blow one or more of the rectifiers since there's a direct path from the hot side through the rectifier to common (ground). Yes, neutral is connected to ground. That's why you blew the rectifier. If you want a grounded connection from a line powered rectifier, then you can only use a half wave rectifier. But using any line powered circuit is dangerous since you are not isolated from the AC power and a lethal shock is possible if you touch any part of the circuit when also touching ground.
__________________ Carl Curmudgeon Elektroniker | |
I am confused about one thing. If neutral wire is connected to ground then it means the potential of the Hot wire is changing between +120VAC to -120VAC during the cycle. Potential of the neutral is constant 0V. So one end of the output is always at 0V. So how does it causing a short? I have attached a pic too to make myself more clear. | |
| | #6 |
If you look at the Full Wave Resistive Supply you will see the 4 diodes in the bridge. If you connect the 0v output to say the lower AC line, you will short-out the left lower diode. This means the top left diode will work when the AC is in one direction but become a short when the AC reverses. The only solution is to produce a half-wave supply as shown in the 4th circuit. That's why it is important to draw a clear circuit diagram so that you can see exactly what is going on. | |
| | #7 |
Can you explain me one thing and I am contrdicting myself. If the neutral is always grounded how does the rectifer circuit works in the negative cycle. Assume that it is driving a capacitive load? My doubt is that during positive half cycle capacitor will get charged and when the negative cycle comes bottom right diode(in your figure) will be reverse biased as the anode is grounded and cathode is at poitive voltagevso there is not path for the current to flow. | |
| | #8 | |
In your diagram the bottom right diode is shorted out, so the bottom left one will explode with a large BANG as it's directly across the mains. | ||
| | #9 | |
__________________ Carl Curmudgeon Elektroniker | ||
| | #10 |
Thanks Carl. You are right. They are not at the same potential. The output potential of one terminal varies from 0 to 170V and that of the other from -170V to 0. However I still wonder how does after getting charged in the positive half cycle where one end is at +170V and other is at 0V how does the potential of the terminal changes to 0V and -170V respectively in the negative half cycle? ![]() Te problem is I can not decide which diodes will conduct? | |
| | #11 |
Stare at this for a moment. R2 is there just to fool Spice into letting me rename Gnd to be "Neutral" Note what V(Plus) and V(Minus) are doing. Also note what the differential voltage V(Plus,Minus) looks like. Still think you can tie "Minus" to ground?
__________________ Mike ML. Last edited by MikeMl; 9th November 2009 at 04:32 AM. | |
| | #12 |
Thanks Mike for sending the waveforms. Yeah they are not at the same potential I understood that. What I am still wondering is during the negative half cycle, V1 is going towards -170V. In this case how V(plus) is reduced to 0V. Just for learning purpose, I am curious by which path V(plus) is decreasing. In the negative half cycle: D2 is reversed biased initially. (because V(plus) is higher than V(neutral). D1 is reverse biased too because of the same reason. Where is the path then?? | |
| | #13 |
Here are the currents through the four diodes
__________________ Mike ML. | |
| | #14 |
Ok. Currents are as expected theoretically.
| | #15 |
| Message deleted!
__________________ Mike ML. Last edited by MikeMl; 9th November 2009 at 06:58 PM. | |
| bridge, connected, outlet, power, problem, rectifier, wall |
| What is this outlet on the wall? | claudia | General Electronics Chat | 14 | 10th August 2009 07:28 PM |
| makes something that runs on battery, run on wall outlet | peppers | General Electronics Chat | 13 | 21st April 2009 09:20 PM |
| Bridge Rectifier efficiency problem | MarcL | Electronic Projects Design/Ideas/Reviews | 5 | 10th December 2008 08:52 PM |
| Power Supply question [bridge rectifier] | ArcaneDreams | General Electronics Chat | 26 | 26th December 2006 03:33 PM |
| full-wave bridge rectifier problem | MsStateDawg | Electronic Projects Design/Ideas/Reviews | 11 | 5th January 2004 07:52 PM |
