Old 6th November 2009, 05:32 AM   #1
Default Simulation using Proteus package...help
Hello. I trying to simulate a project of mine with proteus 7 professional. I am stuck with a certain section of my design. I need to transmit a 120khz pulse through the 230ac power line. This is done by a tx circuit connected to one end of the ac signal and at the other end of the ac signal there is a rx circuit. So basically the tx circuit inputs a signal onto the ac signal! How can this be done?
reenalalu is offline
Old 8th November 2009, 03:27 AM   #2
The idea is commonly known as a carrier current transmission system. Your TX signal can be injected into the mains by first injecting it into the primary of a signal transformer designed to pass 120 KHz, and to withstand the mains voltage. The secondary of the transformer is connected to the mains through a series coupling capacitor selected to provide high reactance to the 60 Hz mains frequency and relatively low reactance to the 120 KHz signal. The same technique can be used on the RX side to recover the signal. The transformer could be selected to provide some degree of impedance matching, if necessary, and signal voltage boosting on the RX side, since the mains impedance at 120 KHz is in the tens of ohms.
Realistic simulation is somewhat problematic since the mains is a complex system that varies greatly from one installation to another with all sorts of potentially interfering signals from the various loads that one finds connected to it.
ccurtis is offline
packagehelp, proteus, simulation
Character LCD Simulation in Proteus ISIS pradhr Electronic Projects Design/Ideas/Reviews 3 30th October 2009 06:38 AM
Proteus 7 Simulation Wilksey General Electronics Chat 10 2nd September 2009 06:06 PM
Proteus PIC simulation colin mac Micro Controllers 7 15th July 2008 04:22 PM
Proteus 7 simulation problem jhanus Micro Controllers 0 8th June 2007 10:36 AM
