Hi there I am wanting to build I believe a fairly simple circuit. I want to put a probe in my computer that turns on a fan when it senses 40 degrees C and turns off when the temp drops below 40 C. Simple on or off I don't want it to be variable speed or anything. I have some temperature probes from a temp display panel for my computer. The simple probes give temp info by resistance (obviously). Temp probe give a resistance of about 10k at room temp I want the circuit to turn on when it has a resistance of about 5.7K I would also like to have a pot to adjust this voltage as well I believe the 12 volt fan can draw about .5 amps, but probably best to assume .75 amps to be safe. If its easier I can just use a relay to handle the higher current. I just started messing with Tiny CAD and I have attached what I have thus far, its not much.. I believe I could use a transistor to do this, but I have no idea on how to do the calculations for anything. Any help is much appreciated! thank you very much, Seth | |
After much research I was able to find this diagram: Thermo-Fan to keep your amplifier cool I think I could just do this instead. The part of it that I am unsure about it the zener regulator. Does it need to be 10v or does it matter? Seth | |
[edit] His notes are helpful: "If you just happen to have a regulated 12V supply handy, leave out the 10V zener diode, use a short circuit for R5, and just use the circuit as is."[/edit]
__________________ de KI6RWX Last edited by mneary; 7th November 2009 at 08:46 AM. | |
KISS, temperature switch, thermostat. | |
Hi If you want to build that circuit here is the PCB layout in Eagle 5.6.0. it is zipped. I use this circuit and have so for three years, it is excellent. Cheers Andrew | |
| | #6 |
thanks Andrew, the circuit looks great. What kind of set-up do you use for the diodes and what type of diodes do you use? Thank you, Seth | |
| | #7 |
Hi I happened to have two Gl 9242 laying about so used them. One broke and ended up with one GL9242 and one 1N4141. I have noticed that the circuit does not like two or one for that matter 1N4141. Dont forget R8 needs calculating according to the article. I use the fan for a completely different application, it is set to come on at ~28°C and is at full speed at ~35°C. This is nice as it is very quiet at the lower temperatures. Cheers Andrew | |
| | #8 |
dear i want some ideas of circuit projects? plz give me some ideas also give me circuits diagram. | |
| computer, controlled, fan, temperature |
| Temperature control fan | baxev2005 | Electronic Projects Design/Ideas/Reviews | 16 | 13th March 2009 07:07 AM |
| Heat controlled fan. (High temp = fast fan) vice versa | zac-uk | Electronic Projects Design/Ideas/Reviews | 3 | 15th November 2007 03:33 PM |
| Computer Controlled Radio-Controlled Car help | Suds | Electronic Projects Design/Ideas/Reviews | 6 | 29th March 2007 10:23 AM |
| Linear temperature fan control | bryan | Electronic Projects Design/Ideas/Reviews | 2 | 19th January 2004 04:40 AM |
| InfraRed Controlled Fan | Cupid | Electronic Projects Design/Ideas/Reviews | 5 | 7th June 2003 07:23 PM |
