Old 5th November 2009, 01:40 PM   #1
Default op amp power rails
Would apprieciate some advise on an op amp question.
An existing op amp circuit fed from split rail supplies of +/- 5v, inputing about +/- 10mv and outputing +/- 1v.
If just the -5v rail was reduced by 5% to 4.75v would the output signal of +/- 1v be changed and if so, would it be just on the negative side or the whole signal ?
( its not my circuitry so cannot actually test it )
thanks.
Wp100 is offline
Old 5th November 2009, 02:09 PM   #2
As long as there is some room between the output level and the supply rail the effect should be minimal. Everything changes as the output approaches the supply rail and other more subtle changes may occur as one or both supply rails collapse. AFAIK it would be possible to run your application with +8V and -4V or any other non symmetrical combination where there was sufficient headroom between the output peak and the rail.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 5th November 2009, 02:46 PM   #3
Hi PB,
Thanks for that.
Wp100 is offline
Old 5th November 2009, 02:59 PM   #4
Not enough info to answer. If the voltage applied to either the inverting or non-inverting input is developed from a resistive network which has a connection to the -5V rail (or the +5V rail), then a change in the rails will cause a proportional level shift in the output. If the inputs are connected only to external signals, ground, or a regulated voltage reference, then there will be only a tiny shift as the supplies vary. Look up the Power Supply Rejection Ratio (PSRR) for the subject opamp.
Mike ML.
MikeMl is offline
Old 5th November 2009, 05:54 PM   #5
Hi Mike,
I do not have the circuit or board, but will pass the info back to the owner.
The point to be made here is do not change anything unless you are 110% sure !
thanks again
Wp100 is offline
amp, power, rails
7805 - noisy rails westhomas General Electronics Chat 18 16th October 2008 09:20 PM
Op Amp Power Rails richard.c Electronic Projects Design/Ideas/Reviews 5 28th March 2008 01:25 AM
Switching of dual polarity rails... Dr.EM Electronic Projects Design/Ideas/Reviews 2 12th March 2005 03:35 PM
555 makes rails oscillate Megamox Electronic Projects Design/Ideas/Reviews 3 11th January 2005 06:35 PM
Power rails/Electro-mechanical problem Snowman Electronic Projects Design/Ideas/Reviews 19 17th October 2004 01:13 AM
