Hi, currently i am working with a project which consist of 600 led. We split it into Part A(consist of 300 led) and Part B(consist of 300 led). So now the problems comes in, how do i let part a light alternately with part b? I am supply 16 AA" battery hence 24v. a am using Super bright led. But i do not want to use mirco controller to control the whole circuit, is there any other way i can solve this problem? Thank in advance. | |
As I told you in the other thread; you cant get blood out of a turnip! To run 600 leds it will take a car battery, or at least a pretty big SLA. You ain't gonna do it with AA batteries.
__________________ Mike ML. | |
you reply to my post before? I didn't see my thread in here before, i once tot that the mod has delete my thread. I have already try testing on the 600 leds already. It can be light up brightly. just that now i want it to flash alternately. | |
| At least, not for very long...
Hmmm.Okok..Thank mike..Appreciated it alot..But if i were to connect all the led in parallel, will there be any side effect?
| | #6 |
Besides wasting a TON of power in a resistor? No.
| | #7 | |
An active current source would be better because the LEDs would get pretty dim once the batteries discharged to around 21V which is only 1.3V per cell.
__________________ Inside every little problem, is a big problem trying to get out. Last edited by kchriste; 5th November 2009 at 04:55 AM. | ||
| | #8 |
What is it for?
| 600, control, led, mircocontroller |
| 600:600 ohm center tapped line matching transformer | dramrattan | Datasheet/Parts Requests | 4 | 30th January 2009 02:26 AM |
| power inverter 600 v dc to 110 ac | chris54 | Electronic Projects Design/Ideas/Reviews | 25 | 30th December 2008 11:15 PM |
| 600 watt regulated DC power supply | paulw271 | Electronic Projects Design/Ideas/Reviews | 10 | 4th December 2006 02:33 PM |
| LED PWM brightness control - transistor value and Piezo buzzer volum control | llrjt100 | General Electronics Chat | 17 | 12th May 2006 09:42 PM |
| Light an LED from a 600 watt speaker? | cocoadev | General Electronics Chat | 10 | 2nd November 2004 06:32 AM |
