Old 4th November 2009, 11:23 PM   #1
Default gear motor advise
i have one of these gear motors. 6VDC 3RPM Gearhead Motor-The Electronic Goldmine What i am wanting to do is to run it on it's slowest speed. I have a 12v. and i need to bring it down to 3v. Can i use resistors to drop the voltage? or a rheostat to trim it down to 3v? i'd rather not speed the money on a pwm if i don't have to.
cbiblis is offline
Old 4th November 2009, 11:51 PM   #2
Is this battery operated? Why not use two AA batteries?
ke5frf is online now
Old 4th November 2009, 11:55 PM   #3
i will be designing a new thermostat to include the motor driver. i have a 12v 6amp transformer on board. I am using 100ma for the thermo, 100ma for the lighting (leds) and i would like to tap the motor supply in as well.
cbiblis is offline
Old 5th November 2009, 12:02 AM   #4
A resistor is going to get hot. The motor sound like it was intended to run on 12v. PWM is your best choice, not really that bad. You would also keep the motor's torque, won't have much power with a resistor. Would also help if you gave some info on the application. Is it a single speed/direction, or variable speed, reversing?
HarveyH42 is offline
Old 5th November 2009, 12:02 AM   #5
you might use a pot connected directly to the motor, but it has to be a wire wound type to dissipate enough power not to burn up.
Using an N-channel-Fet transistor any pot suffices to vary the motor voltage.
Here is a super simple circuit to change motor voltage/rpm.
Boncuk
Boncuk is offline
Old 5th November 2009, 01:42 AM   #6
If this will work, can i use the buzz11a? Reason i ask is i have 5 with out a use for them.
cbiblis is offline
advise, gear, motor
motor + worm gear + spur gear oem_odm Robotics Chat 1 29th August 2009 06:40 AM
need advise... moinmoin Electronic Projects Design/Ideas/Reviews 4 18th June 2008 06:12 AM
I need some advise. laiza Electronic Projects Design/Ideas/Reviews 1 21st May 2005 10:55 AM
Need help/advise RAA Electronic Projects Design/Ideas/Reviews 18 15th May 2005 11:32 AM
