Old 4th November 2009, 02:34 PM   #1
Default Toggle between frequencies
Is it possible to toggle between two precise crystal frequencies? Also, one of the frequencies is very rare and it is hard to get the crystal. Is it possible to use some sort of variable crystal oscillator whos frequency could be set with componants? the two frequencies are 17.743472mhz and 14.31818mhz.
jaypayte is offline
Old 4th November 2009, 03:16 PM   #2
Nevermind. Misunderstood the question.
ke5frf is online now
Old 4th November 2009, 03:28 PM   #3
It's dead easy to switch crystals, either directly switch the crystals, or use separate oscillators and switch them. For examples, check any of the old 145MHz crystal based transmitters.
For your obscure frequencies, simply have them made for you, it's a common requirement and crystal manufacturers offer a 'made to measure' service.
Nigel Goodwin is online now
Old 4th November 2009, 11:08 PM   #4
Probably best to have two oscillators, each of which can be trimmed to frequency. Switching between them can be done by switching power to them. If rapid switching is desired, then leave them both running and multiplex the outputs using a 2:1 mux.
Mike ML.
MikeMl is offline
frequencies, toggle
Are any of these crystal frequencies 'special'? astronomerroyal Micro Controllers 3 3rd September 2008 09:34 PM
Using MCU to compare 2 voltages/frequencies pablome Electronic Projects Design/Ideas/Reviews 0 7th April 2008 01:39 AM
near exact clock frequencies arod General Electronics Chat 7 25th February 2007 07:56 PM
Op-Amps at high frequencies YAN-1 Electronic Projects Design/Ideas/Reviews 26 17th August 2006 03:19 PM
Sinusoidal generator of 3f,5f,7f frequencies arunaishus Electronic Projects Design/Ideas/Reviews 1 11th March 2004 01:55 PM
