Old 4th November 2009, 06:42 AM   #1
Default how do I isolate DVOM probes from the power source
I have this DVOM:
http://www.rpelectronics.com/Default...s/PM-1029A.asp
DVOM uses 9V for power display and electronics
A 24v battery and a linear voltage regulator (set at 9V) feeds the circuitry of DVOM. I can measure any DC voltage within its preset range (0 to 200V) as long as that is part of separate circuit, say a battery, another power supply etc.
but when I try to measure the voltage on same battery pack that feeds the voltage regulator the DVOM digits disappear and only couple of segments are displayed in first digit.
removing the ground DVOM probe from the circuit restores the digits to "0000".
apparently negative/ground for 9V DVOM and negative/ground probe do not play well.
so, how do i isolate those two negatives from each other so that I can measure the power from same battery pack that feeds the DVOM via voltage regulator?
tesla2008 is offline
Old 4th November 2009, 07:03 AM   #2
Buy a dPm that includes the isolated power supply. Or build a switcher with an isolated winding on the inductor
Mike ML.
MikeMl is online now
Old 4th November 2009, 05:03 PM   #3
I see
that seem to be par of the design that you cannot use the common ground
thanks for the information
dvom, isolate, power, probes, source
Isolate happyfpga Electronic Projects Design/Ideas/Reviews 9 6th October 2008 02:19 AM
need to isolate two grounds in my circuit.. raviram87 Electronic Projects Design/Ideas/Reviews 13 17th February 2008 04:37 AM
How to isolate and wire? neko_whisker Electronic Projects Design/Ideas/Reviews 11 1st January 2008 09:44 AM
logic probes digital General Electronics Chat 3 13th August 2005 12:07 AM
o-scope probes jrz126 General Electronics Chat 1 1st March 2005 12:04 AM
