Old 4th November 2009, 06:09 AM   #1
Default PCB help!!!
Hi all, I am new to this forum, and I come in search of aid in making a PCB!
I'm getting stuck in trying to transfer the PCB design to the copper board using the laser printer/toner method. I have tried all kinds of paper, different laser printers, two or three different irons, several copper boards, and nothing has worked!!! I can't possibly be messing up such a simple procedure, but so far I have had absolutely no luck.
Would anyone in these forums be willing to print and transfer a design to a copper clad board? I've got the tools and chemicals to etch and drill, so I would really only need the design transfered to the copper board. I'd be willing to compensate you for your efforts!!!
Please PM me if you're interested or otherwise
Thank you all for your time!
musikmeister is offline
Old 4th November 2009, 06:49 AM   #2
This is not really an answer to your problem, however if you are looking for someone to help you etch a PCB it is a good idea to fill in your location so they will know what will be required to ship materials back and forth.
Brevor is offline
Old 5th November 2009, 10:26 AM   #3
Since you give no location, you probably will receive no help.
de KI6RWX
mneary is offline
Old 6th November 2009, 03:14 PM   #4
and this is why I am a noob ;-) location fixed.
I'd be willing to cover shipping costs both ways anyway.
Old 6th November 2009, 07:43 PM   #5
Post the artwork. Is it single or double sided? How large?
Bill
Smart Kits build Smart People
Old 6th November 2009, 08:13 PM   #6
You can make a good transfer with an iron but there is a learning curve. For most people it is easier to use a laminator.
There are numerous threads on this and other sites on making PCBs using toner transfer.
Read the tutorial
Create High Resolution PCBs at home!
If you want to use the Pulsar paper and foils in the US the can be had from Mouser.com.
3v0
BCHS/3v0's Tutorials
3v0 is offline
Old 7th November 2009, 06:52 AM   #7
What part of the procedure is giving you problems ?
Brevor is offline
Old 7th November 2009, 02:30 PM   #8
Hi musikmeister,
are you German? In English it would literally be "music master".
It seems to me that you have more machinery in your hobby shop than you are able to use properly.
Following 3V0's advice you should better use a good qualitiy laminator instead of an iron. With an iron you never know how hot a an area has become transferring toner from the paper print onto the copper clad. He further pointed out this is a process of learning - a pretty long and hard way sometimes.
Using photo positive method with UV-sensitive PCB material you should have a good laser printer, UV-exposure box and the necessary chemical products and a transparency to be used to expose and develop the "film".
For that method disable the printer setting "toner saving" and try to print an image of completely black traces and pads. (If necessary mount two films on top of each other. Traces and pads must be deep black!)
Do not "fill pads" using that option if your software offers it. Unfilled pads are easier to drill after etching, because the drill centers itself when hitting "bull's eye". (±0.25mm, otherwise kiss off the drill and say good bye to €7.50 )
Possible overexposure must be compensated for by reducing development time.
As soon as traces get visible check at short regular intervals for progress of development. When the PCB is developed to a point when no clouds of photoresist are visible anymore, remove it from the developer and rinse immediately and thoroughly. (Developer keeps on working until it is stopped by rinsing!)
When done drill the board as specified by drill diameters in your drill file.
Any more questions? PM me.
Regards
Boncuk
Boncuk is online now
circuit board, copper clad, help needed, pcb
PCB schematic for 16 led 12 pattern pcb diecast lighting Electronic Projects Design/Ideas/Reviews 54 16th August 2009 06:18 PM
First PCB?? Mark68 General Electronics Chat 45 6th July 2009 06:01 AM
Difference between double sided PCB and 2 layer PCB darvaish Electronic Projects Design/Ideas/Reviews 2 10th March 2005 06:32 PM
pcb by uv andrew2022 General Electronics Chat 4 16th June 2004 12:02 AM
PCB mahinda jayasinghe Electronic Projects Design/Ideas/Reviews 4 1st June 2004 05:26 PM
