Old 4th November 2009, 05:56 AM   #1
Default Help needed in powering 500 flashing led.
Hi dudes, currently i am working on a project which will require to power up 500 white led. The project is just to let the 250 led flash alternately with another 250 led.
I have try using the 555 timer to control, but the Power supply i am supplying is 16 x AA" battery which will add up to 24v? I added in so much battery is because, LED is a current component. So in order to light them up, i have to supply enough current for all of them?
But now the problem comes in. the IC 555 timer can only take up to 15v max.
The circuit i am currently using is this LED Flasher Using 555 IC | Free Circuit Diagram
I have tot of another method is to use 2 of the circuit(above). but the flashing wouldn't be alternately, due to the time different i guess.
Can any dude here help me with this? Much appreciation.
RaySoul is offline
Old 4th November 2009, 11:07 AM   #2
Have a look at the link futher down the page at the link you posted: LED Flasher Circuit Using Transistors | Free Circuit Diagram
dougy83 is offline
Old 4th November 2009, 01:26 PM   #3
A single LED has a forward voltage drop of between 2 to 3.5V, depending on color. To power 250 of them in a single series string, it would take a minimum of ~500V, so obviously, you have to wire small groups in series where each group shares one current limiting resistor, and then wire many groups in parallel.
This means you can choose an operating voltage which powers a group, like 15V which might power 5ea 2.2V Leds, leaving 4V across the current limiting resistor. Obviously, it would take 25 groups in parallel to get 250 Leds.
Assuming you plan to operate the groups at 20mA, this means that the total current through 25 groups would be 1/2A. At 1/2A, your proposed AA batteries would last about 1 min!!! Try a 12V car battery.
Mike ML.
MikeMl is offline
Old 4th November 2009, 03:48 PM   #4
Default Multi LED flasher thingy schematic
I knocked up a quick schematic of what you will need to do. This shows 90 white leds connected to 6 of the 12 ports of a PIC16F676, which drives logic level mosfets.. It's all easily scalable to use any number of leds, but you should get the basic idea.
Writing the code for the pic would be a simple matter, and shouldn't take more than about an hour.
The unused ports have been tied to ground, but could be assigned to push buttons to allow speeding up of the flashing, resetting etc etc...
I haven't tried this schematic, but it's really simple.
Shax.
A bus station is where a bus stops...
A train station is where a train stops...
On my desk I have a work station...
Nuff Sed!!!
Shax is offline
Old 4th November 2009, 09:32 PM   #5
Try this wizard.
LED series parallel array wizard
Ron
RonH is offline
Old 5th November 2009, 03:59 AM   #6
Wow..Thank for all replies..Really appreciated it..
But as i have connect all the led in parallel, is there any bad side of it?
RaySoul is offline
500, flashing, led, needed, powering
12V Car flasher to trun on led, at the same time Flashing is on, Led is on. Tricky111 General Electronics Chat 3 18th September 2009 06:18 AM
Flashing LED, needed planty Electronic Projects Design/Ideas/Reviews 5 17th January 2009 12:39 AM
flashing LED,s mick the builder Electronic Projects Design/Ideas/Reviews 7 15th December 2006 09:18 PM
Flashing LED circuit with photoresistor switch help needed angie1199 Electronic Projects Design/Ideas/Reviews 15 15th August 2006 05:15 PM
Powering Led with a lower voltage battery 1.5v for 3.6v LED stakx2002 Electronic Projects Design/Ideas/Reviews 4 5th June 2004 07:07 PM
