so hows it done? i have a 2 way GMRS radio (walkie talkie) and i want to increase the range? also if there is a coil in it can i technically change it to play on fm radio frequencies? lastly what are some cool ways to modify a 2 way radio? | |
you can generally tweak the tuning coil of a radio to receive frequencies that are close by to the original tuning range . for example, stretching out the coil of a broadcast band fm radio to receive the civil aircraft band 118mhz above,though the former is fm and the latter transmissions are AM,you can still here the transmissions. but the GMRS radio like you have works on the UHF band that is 450-470mhz so practically there is no way to tweak it to receive the fm broadcast band. for increasing the range all you have to do is make an rf power amp and fix a relay to trigger it on when ur walkie talkie is transmitting. cheers | |
| | #3 | ||
| There are three common ways: Increase the transmitter power Increase the receiver sensitivity Increase the antenna gain Quote:
Does the radio have a removable antenna? If not I think you are stuck. Quote:
I guess it all depends on what you mean by "cool". Working outside in the snow and ice in the middle of winter would be cool. JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | |||
| increasing, radio, range |
| Increasing Range on Walkie Talkies | SlicRic | General Electronics Chat | 10 | 1st June 2009 03:56 AM |
| Increasing transmitting range? | wikisi | General Electronics Chat | 4 | 21st February 2009 04:44 PM |
| Increasing Vd for narrow frequency range | SaintK | Electronic Projects Design/Ideas/Reviews | 0 | 1st March 2006 06:31 AM |
| increasing range of ir | addyismad | Robotics Chat | 3 | 27th December 2005 07:43 AM |
| increasing RF range | pittuck | General Electronics Chat | 2 | 25th January 2005 07:44 AM |
