Old 4th November 2009, 12:40 AM   #1
Default IGBT Gate Driver
I have recently heard of comparators that have push pull outputs, could they be used as an IGBT driver? Also, does anyone have any part numbers for these types of comparators?
Metal-Oxide-Semiconductor Flame Effect Transistor
MOSFET KILLER is offline
Old 4th November 2009, 05:00 PM   #2
Hi MOSFET KILLER, the LM393 and LM339 are two that have what your looking for.
BUT I would never use them as gate drivers! They DON'T have enough current to turn on a gate fast enough! The mosfet would spend too much time in transition and run hot.
Cary
shortbus= is offline
Old 4th November 2009, 08:04 PM   #3
Isn't the LM393 an open collector output?
I have several LM393 comparators, is there a way to use the open collector to drive a pair of HGTG30N60B3D IGBTs?
I have a nearly unlimited supply of low power BJTs but like you said I am going to need a large current to turn the IGBTs on.
Would it be a good idea to bias the gate of the IGBT during turn off, to switch more efficently.
Old 4th November 2009, 10:20 PM   #4
Use a proper driver chip. Or build one out of discrete components. The current requirements are way beyond op amps capabilities.
smanches is offline
Old 5th November 2009, 02:00 AM   #5
Ok, so I will use a pull-up on the comparator and that signal to drive the base of a transistor inverter that will turn on the IGBTs and bias them on turn off.
Or is there a better way to drive the IGBTs using discrete components.
Old 9th November 2009, 06:15 PM   #6
If you have to use discrete components, build a totem pole driver. This is probably the most efficient for switching MOSFETS/IGBTs.
It's much simpler to just buy a driver chip though. They are not expensive and usually have a lot more features in them than just the driver circuitry.
smanches is offline
comparator, driver, gate, igbt, push-pull
IGBT Gate Turn on current drawing alisarhangpour General Electronics Chat 3 30th November 2006 03:45 AM
IGBT gate drive Styx Electronic Projects Design/Ideas/Reviews 9 1st May 2004 05:13 PM
Gate drive circuitry for IGBT half-bridge twinkleBell Electronic Projects Design/Ideas/Reviews 1 30th January 2004 11:32 AM
