Old 4th November 2009, 12:20 AM   #1
Default Help with Totem-Pole slotted IR sensor
I have an instrument which sparges a gas stream through a bubble tube. This allows water in the gas stream to condense. However, when running lots of samples, the jacket can actually overflow soaking the downstream drying agent (and generally causing a mess). A while ago, I made a bubble sensor with a slotted optical switch. I used it in "switch mode" into a microcontroller as shown in this application bulletin. I want to do something similar, but I have a different slotted switch (inherited it). It is called a totem-pole. The datasheet here. I'm very confused. I understand "powering" the anode/cathode with a current-limiting resistor to "light up" the IR LED. What I don't understand is that this model has three wires on the "transistor" side. It appears as VCC (white), ground (green) and output (blue). With the four-wire version, I used a 10K resistor as in Figure 1 on the app note to create a bubble detection "switch." What I don't understand on this version is whether I have to calculate an R2? Could I just hook the anode to +5V through a limiting resistor, then hook cathode and "ground" to ground, then the white wire directly to 5V? Would I get high-to-low or low-to-high on the output (blue) wire? I don't understand which components are "inside" the package on Pg. 3. On the app note, there's a rectangle around the physical device on the circuit diagram. Has anyone ever used one these and can provide some direction? Thanks as always...
tboydva is offline
sensor, slotted, totempole
Smallest tool size milling slotted holes Boncuk Chit-Chat 8 25th May 2009 05:35 AM
4 pole motor hansjuan General Electronics Chat 1 31st October 2008 02:56 PM
Speed of ? Slotted Senser/Photo-Interrupter oem_odm General Electronics Chat 1 12th July 2008 05:13 PM
slotted optical sensors microzone Datasheet/Parts Requests 4 30th April 2006 06:53 AM
Infrared "slotted switch" sensor Electric Rain Electronic Projects Design/Ideas/Reviews 3 7th December 2005 10:42 AM
