Old 4th November 2009, 02:30 PM   #16
Originally Posted by NHN View Post
On it already with google
So the resistor doesnt need to be directly inline with the circuit as such to effect the voltage, it can also be in parallel aswell as series to affect things overall, this is something I didnt realise, explains some things to me now.
Been reading up quite rightly as you suggested.
I'll get there & again thanks for the help.
Very good. But let me comment on "So the resistor doesnt need to be directly inline with the circuit as such to effect the voltage"
I know what you are asking here, you are referring to a parallel circuit, in which case yes, the resistor doesn't have to be in series with other components in a circuit (switches, LEDs, transistors, capacitors etc) to have an effect, but I will correct you one one thing, which you will learn as you read...when a resistor is in parallel with another component in a SIMPLE parallel circuit, it doesn't have any effect on voltage but rather it divides the CURRENT between the different branches of the circuit.
Also, remember this point...All components in an electronic device, be they in series with each other or in parallel, are PART OF the circuit and work together at the same time. Well, at least this is true when all components are switched "on" and actively working in the circuit. While you can analyze a circuit as the sum of its parts and study each part independantly, remember they all act together and as such are ALL part of the circuit. Like players on a soccer team (football for the Brits on board LOL), each player has his job, forward, back, goalie etc. No one player is more important than the other, though some have a more active roll, they all work together to score points for the team.
ke5frf is offline
ground, query, resistor
Tying to ground/5V, via resistor? edeca General Electronics Chat 2 26th February 2009 10:48 AM
Why before base (of bjt) a resistor goes to ground? alphadog Electronic Projects Design/Ideas/Reviews 13 25th February 2009 02:15 AM
Resistor Wattage Rating Query Kempachi343 General Electronics Chat 5 26th January 2009 01:56 PM
Wire wound resistor query Nameless1 General Electronics Chat 12 14th August 2007 07:08 PM
Reference ground resistor nickkka Electronic Projects Design/Ideas/Reviews 1 19th April 2007 10:01 PM
