Hi, can anyone tell me how to design a 0.5W audio amplifier with mute and volume control? The design should allow user to switch between different bandwidth and also light up specific LED when different bandwidth is selected. Thanks..=)
you are not being clear about what you want actually. by bandwidth, do you mean audio bandwidth or do you mean different channels that you want to switch? cheers- deepak | |
The datasheet for the TDA7052A shows a DC volume control with mute. You need to design and make your own bandpass circuits with some opamps, a switch and some LEDs.
To deepak: the project require a preamp stage that amplified the signal and then it will switch by using a transistor(which i am not sure how it is done), the switching will switch to either a normal music bandwidth stage name as music or it can be switch to a bandpass filter which has a freq of 300-3300 Hz name as voice... and then after this it will then be amplified using TDA7052A with volume and mute control.. when music stage is turn on LED red will light up, when voice stage is turn on LED yellow will light up and when mute is on LED green will light up. i am not sure on which preamp i need to use and how to use a transistor as a switch, components such as uA741, 2N2222, toggle switch.. etc are given. | |
It sounds like school-work. If you don't know how to design it then ask your teacher to teach you how to design it.
| 05w, amplifier, audio, control, designing, mute, tda7052a, volume |
| designing audio amplifier circuit | kavi_e2 | Electronic Projects Design/Ideas/Reviews | 0 | 31st January 2009 01:28 PM |
| To design a 1W Audio Amplifier with mute and volume control | apricot_star | Electronic Projects Design/Ideas/Reviews | 2 | 30th October 2008 01:49 PM |
| How Volume and Mute Operation will happen? | Pramoda.M.A | General Electronics Chat | 0 | 14th October 2008 07:39 AM |
| Low wattage amplifier with volume control | frankwas | Electronic Projects Design/Ideas/Reviews | 6 | 20th September 2004 06:37 AM |
| Audio Amplifier Designing Project | silverferro | Electronic Projects Design/Ideas/Reviews | 3 | 26th August 2004 11:05 AM |
