Old 3rd November 2009, 06:22 AM   #1
Default how to build current sensing circuit with timer
hi there
can anyone tell me how can I build a circuit that would detect when a plasma TV is under load (wakes up) and then turn an light bulb/fluorescent tube 'on' via timer.
the idea is when there is change in power draw due to plasma TV going from "sleep" mode to power mode a current sensing circuit turns on electronics with a relay that then turns a light and holds it in "on" position for say 1/2 hour or so.
input voltage to plasma TV is 120V.
amperage that TV draws when it wakes up is probably in range of 5 A or more
and when in sleep is most likely in single digit watts.
thanks for any suggestions
tesla2008 is offline
Old 3rd November 2009, 12:47 PM   #2
You could use a current transformer on the plasma tv's power cord, use this and a comparator. When the current goes up the comparator output will be pulled up by a pull-up resistor and turn a relay on.
Metal-Oxide-Semiconductor Flame Effect Transistor
MOSFET KILLER is offline
Old 3rd November 2009, 04:50 PM   #3
thanks for you answer
what kind of current transformer can i use to accomplish this?
would something like this work:
AC Current Sensing Transducers
Current Sensing Transducers Overview
build, circuit, current, sensing, timer
How can I build a stop/start timer into a 3 volt circuit? thiscountryside Electronic Projects Design/Ideas/Reviews 19 28th August 2009 06:16 PM
AC Current Sensing without using a current shunt jbarnaby2000 Electronic Projects Design/Ideas/Reviews 27 20th May 2009 01:24 AM
current sensing in AC rjvh Electronic Projects Design/Ideas/Reviews 12 18th June 2008 04:32 PM
Looking for current sensing IC DWE&C Electronic Projects Design/Ideas/Reviews 3 8th June 2007 06:19 AM
:: Current Sensing :: HELP!! suby786 General Electronics Chat 10 10th March 2007 03:30 AM
