Hi friends , Can anyone help me to tell how i can implement this work ? I want to build a circuit for a pulse width modulation AC voltage regulator . This cicuit is to vary the amplitude of an AC voltage using pwm technique. The ac chopper should use bidirectional switches . The load could be a light dimmer, ac heater or an induction motor. I have not really got a clear knowledge about this work .Please,assist ! Thanks . | |
How would YOU do it?
Yes, i want any suggestion on how to go about that. Possibly, circuit diagrams for the ac chopper (using bidirectional switches) and the pwm . If you know any link, you can direct me . Thanks .
I belive that IGBTs have a diode built in to allow for bidirectional switching. And for the PWM signal just use a 555 timer.
__________________ Metal-Oxide-Semiconductor Flame Effect Transistor | |
Hi, Thanks for your help.I got one simple pwm power controller on discovercircuits.com . Can you help to tell me how to interface the ac chopper output and the pwm input ? The input and output should be AC voltage .I mean, the load has to be an ac load , not dc . The circuit input voltage is +6V, so should i first step down the voltage from the 240V supply to 6V before feeding the ac chopper ? The frequency has to be a fixed 50HZ. Do you have any link where i can get an ac chopper schematic, using bidirectional switch ? Thanks for your help . | |
| modulation, pulse, pwm, regulator, voltage, width |
| pulse width modulation (PWM) AC voltage regulator | ogis | Electronic Projects Design/Ideas/Reviews | 0 | 3rd November 2009 02:09 AM |
| Pulse width modulation | Karkas | General Electronics Chat | 13 | 2nd September 2009 10:04 AM |
| Pulse Width Modulation | andy257 | General Electronics Chat | 14 | 27th September 2005 06:50 PM |
| Measuring Pulse width modulation PWM | walters | General Electronics Chat | 44 | 12th June 2005 09:38 PM |
| Pulse Width Modulation to +/- Voltage | brianbek | Electronic Projects Design/Ideas/Reviews | 3 | 26th September 2004 12:21 AM |
