I am designing my first 4 layer PCB, and I am a little confused on how to use the capacitors with it. In the schematic it has capacitors going from the power trace of a component to ground, but on a 4 layer board there isn't a power trace to the component, just an entire plane. how does the component use the right capacitor? Does it matter where I put the cap? Thanks for the help understanding this!
You place the capacitor intended for a particular component as physically close to that component as possible. A component will use all the capacitors to some extent, since all the capacitors are connected in parallel, but the capacitor placed closest to a component provides the most effective bypassing for that component while the other capacitors provide the most effective bypassing function for the other components placed closest to each of them.
Yes, put the capacitor as close as possible to the pin it's bypassing, and use a fat trace between the pin and capacitor to minimize trace inductance. For maximum bypassing effect, flood the top and bottom with ground plane also (fill in all the area between traces) and connect the common end of the capacitor to this flooded plane. Run numerous vias between the flooded plane and the buried ground plane layer.
__________________ Carl Curmudgeon Elektroniker | |
So along with the internal ground plane, use the top and bottom planes as ground planes and connect them all? Also, even though the pad and capacitor are connected by the plane, still connect a trace to them? Do I not connect the positive side of the cap to the power plane, just the trace to the pad? Thanks for all of the good advice!
| boards, capacitors, layer |
| How do you go from low layer to high layer? | electricity86 | Micro Controllers | 4 | 20th March 2009 08:56 PM |
| what is the best pcb software for 1 layer boards? | BOBKA | General Electronics Chat | 22 | 12th May 2007 05:31 AM |
| four layer PCB | Scarr | General Electronics Chat | 1 | 1st April 2005 04:20 AM |
| Multi (more than 2) layer boards | 2camjohn | General Electronics Chat | 7 | 20th November 2004 03:59 PM |
| multi layer boards | grrr_arrghh | General Electronics Chat | 4 | 14th July 2004 02:32 PM |
