I did a google for building a wind direction measurment but can't locate the post on here as one of the searches lead me to Electro-tech. something about using a servo potentiometer to indicate wind direction. If anyone is familiar with this post or how a servo pot could be utilized to indicate wind direction. never worked with a servo but I assume that it would rotate 360 degrees and output an analog resistance reading? planning on connecting to a PIC for the air cannon I am designing or helping to design. | |
The only thing that comes to mind for wind direction is a dual pot where the pots are offset by 1/2 a rotation and no stops. Hard to find. 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
some where on this site (electro-tech a servo was mentioned but can't seem to find it??
MrDeb, This isn't from the forum, but since your already using a PIC; Quadratrak -- Read a Quadrature Encoder -- Chuck's Robotics Notebook Hope it helps, Cary Last edited by shortbus=; 2nd November 2009 at 04:54 PM. | |
And they're red & yellow. I love colorful parts. | |
| | #6 |
| DIY Weather Stations I pm the poster and get some info insight. | |
| | #7 |
| | #8 |
decided to make some 3inch discs using sketchup dividing one disc into 24 sections and other into 64 sections. using an optical slot sensor, use the 24 slots disc for wind speed and the 64 slot disc for wind direction. using a compass, point the wind vane to the north to calibrate at time of install or use then allow to move to indicate wind direction. the 24 section disc for wind speed. using a scroll saw, cut slits into plastic laminate for discs. now to order slot sensors and figure out code for pic. Plan is to use for aiming an air cannon for hitting defined targets at 30, 60 and 90 yards. PIC w/ LCD display to indicate muzzle velocity, wind direction, wind speed, air chamber pressure as well as projectile energy based on projectile weight and muzzle velocity. going to leave nothing to chance as cash in being offered. | |
| | #9 |
Punkin' Chunkin' ? Cary | |
| | #10 |
the contest calls for the use of baseballs. not sure if soft balls or hard balls or maybe even tennis balls?? | |
| pot, servo |
| Switching between two 555 based servo controllers on a single servo. | Aun | Electronic Projects Design/Ideas/Reviews | 0 | 26th March 2009 06:29 AM |
| Trim Pot | joeyb | General Electronics Chat | 12 | 22nd January 2009 07:21 PM |
| convert 50K pot into a 2K pot? | pc88 | Electronic Projects Design/Ideas/Reviews | 17 | 5th April 2008 03:37 AM |
| Replacing RC Servo w/ Custom PCB (Open Servo) | dknguyen | Electronic Projects Design/Ideas/Reviews | 3 | 29th May 2006 03:48 AM |
| What does the A or B mean on a pot? | joecool85 | General Electronics Chat | 7 | 30th March 2006 03:02 PM |
