Old 2nd November 2009, 02:19 PM   #1
Default Convert Squarewave output to Always on.
I need to convert a 50% duty cycle squarewave output of an existing circuit (open collector) to a steady signal with voltage the same as the peak voltage of the square wave. (ie., how to I go about filling in the low cycle of the squarewave without reducing the peak voltage?)
ADWSystems is online now
Old 2nd November 2009, 02:46 PM   #2
Is the peak voltage fixed ?
BCHS/3v0's Tutorials
3v0 is offline
Old 2nd November 2009, 02:48 PM   #3
A capacitor at the base of a transistor?
Mike
My website: www.ElectroBird.net
birdman0_o is online now
Old 2nd November 2009, 09:08 PM   #4
Yes. I think (don't quite understand the question). Same peak voltage on each pulse.
Old 2nd November 2009, 09:11 PM   #5
Wait, if you just want something that is always "high" just make it "high"?
Do you want it to be low when there is no square wave?
Mike
Old 2nd November 2009, 09:41 PM   #6
Use a capacitor to smooth the squarewave just like filter capacitors in power supplies. If you need a cleaner signal just use an NPN transistor, however, you may need to reduce the voltage off of the capacitor so you dont burn out the base of the transistor.
MOSFET KILLER is offline
Old 3rd November 2009, 02:06 AM   #7
I'm tying into an existing circuit. The output is pulse high when active and steady low when not. I think it would be easiest if I had a steady high and low. I'm not sure what the original intention was of the pulse-high/steady-low regime.
Old 3rd November 2009, 02:14 AM   #8
OK. Open collector output, attach pull-up resistor to power, cap to ground, current limiting resistor to NPN base. NPN emitter to ground, resistor from power to collector, steady out should come off collector-resistor junction.
Dumb question time as the answer is completely eluding me. How do I figure the value of the current limiting base resistor? Assmuing a plan-jane 2N2222A NPN transistor, +5V power, and Ic=100mA (Rc=50 ohms).
Old 5th November 2009, 09:12 AM   #9
Conservative: Assume a saturated gainof the 2N2222A of 10. The 2N2222a charts sho an assume beta of 10 for saturation. If your collector current is 100mA, you would want a base current of 10mA. If your supply is 5V, the sum of your pullup and your base resistor would be (5-0.65)/0.01 or about 435 ohms. You can safely increase the resistance by 20% or more.
Less conservative: The gain improves dramatically if you don't demand saturated Vce (0.2V) and tolerate something like 1V Vce instead. If you assume a beta of 20, then you can use resistors more like 1k (like 470 pullup and 470 on the base.)
de KI6RWX
mneary is offline
Old 5th November 2009, 03:35 PM   #10
Why do you need to assume a beta? Doesnt the DS tell you what it is equal to?
Mike
Old 7th November 2009, 08:33 AM   #11
The data sheet gives saturated characteristics with β = 10. This appears to be a common figure in the industry, for a wide range of devices. The charts also show β figures for Vc=5V and 10V, a long way from saturation. β is not given, for example, for Vc=1V which would pull in the relay just fine with a supply voltage of 5V.
I was suggesting that he try designing to Vc=1V, therefore an assumption needs to be made that the β is greater than 10 (saturated chart) but less than 100 or so at Vc=5V.
de KI6RWX
mneary is offline
Old 7th November 2009, 01:10 PM   #12
ADWSystems,
I didn't see anywhere you mentioning the frequency or voltage of the pulsing signal, or how critical the timing is, but it seems that your need would be easily met by a "missing pulse detector" circuit. Google'ing that provides lots of circuits. Like the "Basic Missing Pulse Detector" here:
LM555 Timer Circuits
Ken
KMoffett is offline
Old 7th November 2009, 04:16 PM   #13
The datasheet for all transistors shows a wide range of beta when the collector to emitter voltage is fairly high so the transistor is not saturated.
But the datasheet for most little transistors shows a base current that is 1/10th the collector current when the transistor is saturated, not using beta.
audioguru is offline
convert, output, squarewave
Convert a 5V GPIO output to 240V anyone? thaichovski Electronic Projects Design/Ideas/Reviews 1 24th August 2009 08:06 AM
how to convert Serial Input to Parallel Output ? newbie86 Micro Controllers 1 4th March 2009 01:19 AM
>4v squarewave oscillator? Firnagzen Electronic Projects Design/Ideas/Reviews 10 4th May 2008 02:38 PM
convert input resistance to different output, but how?! pcoghlan Electronic Projects Design/Ideas/Reviews 7 9th July 2004 11:00 PM
Convert Unipolar Squarewave to Bipolar Squarewave evolive Datasheet/Parts Requests 15 5th June 2004 06:24 PM
