Old 1st November 2009, 06:49 PM   #1
Default need more help with sound trigger
hello,
I need to trigger a camera using the sound made by the splash of a drop of water. The sound is picked up using a electret mic placed at about 20-30 cm from the sound source.
The best i could think of is posted here Canon 450D Remote Control but with this design i have to place the mic too close at about 2 cm from the sound source
I also need to adjust the level at witch the camera is triggered (for popping balloons or water drops).
Can anyone help me to achieve this?
PS: I've uploaded two picture with the results I've got so far
need more help with sound trigger-mic.jpg   need more help with sound trigger-testsensibilitatesunet01.jpg   need more help with sound trigger-testsensibilitatesunet02.jpg
gvi70000 is offline
Old 1st November 2009, 07:36 PM   #2
The only suggestion I would make would be non-electronic. At sporting events the camera crews use special parabolic microphones to pick up players and coaches from a good distance.
Of course working out some geometry would be involved, but you might try to mount the electret to face inward in the middle of a parabolic shaped bowl, with the focal point directed at your target and see if you get some mechanical amplification that way.
This might buy you several extra cms or even a meter or two...who knows.
ke5frf is offline
Old 1st November 2009, 07:49 PM   #3
this might me a solution, but is a little bit hart for me to do it
i think i need more gain in the preamp area and maybe a more sensitive microphone
next week i will receive the BCM-9767P microphone from Condenser Microphones with PCB Solder Leads, BCM-9745P, BCM-9765P, BCM-9767P
i hope that will do the job
gvi70000 is offline
Old 1st November 2009, 07:53 PM   #4
This is a sound level indicator, I don't know if it will work, I've made that and at the lowest level it is sensitive, but I don't know if it will be for you, maybe the sound of a drop of water is not very loud for it to detect it, but you can vary the resistors to very low values or maybe you can add another Op. Amp, but that is only a guess 'cause I haven't studied them, i'm sorry it is in spanish, but they areonly a few words.
The LED will lit when the sound level is reached.
need more help with sound trigger-indicador-de-nivel-de-ruido.jpg   need more help with sound trigger-lista-de-componentes-indicador-de-nivel-ve-ruido.jpg
"A person who never made a mistake never tried anything new"
Albert Einstein
Karkas is offline
Old 1st November 2009, 08:04 PM   #5
thanks for the reply
I'm thinking at a preamp with two or three transistors with adjustable gain
a few day ago i was googleing for the same thing and i found this circuit
Amplified Ear - RED - Page38
i made it up to P1(adjust volume) but it doesn't do the job
gvi70000 is offline
Old 1st November 2009, 08:26 PM   #6
Hello gvi70000
Doesn't do the Job or doesn't do anything?
What if you make one of those circuits and amplify the output? wouldn't a simple solution like that work?
Albert Einstein
Karkas is offline
Old 1st November 2009, 08:33 PM   #7
the circuit in the link triggers the camera, but only from about 5cm from the sound source...so it doesn't do the job
"What if you make one of those circuits and amplify the output? wouldn't a simple solution like that work? "
amplify the output...you mean to put one more transistor at the end? I don't understand...can you me a little more specific?
gvi70000 is offline
Old 1st November 2009, 08:55 PM   #8
Well what i ment was, if the problem is that the output gives a very low current instead of that the mic is not detecting anything farer than 5cm, then if you amplify the output you might be able to have a better sensibility, but maybe you'll have to measure the current in the output to know if there's a little one, or there is no current, but I don't think so, the mic of my cellphone is very sensitive, and I just made a test trying to record the sound of the drops of water and it didn't record it, Maybe some expert can give a very effective solution. Maybe you need a more sensitive microphone or a solution like ke5frf gave.
Albert Einstein
Karkas is offline
Old 1st November 2009, 09:00 PM   #9
i will do more research and maybe some one with more experience will give me a solution.I you find a solution , please let me know.
Thank you for replying
I will let you now if i came up with something
gvi70000 is offline
Old 1st November 2009, 09:17 PM   #10
Of course, post your results when you find the solution or I should say a solution.
Good luck.
Albert Einstein
Karkas is offline
Old 1st November 2009, 09:25 PM   #11
Why are you using audio in the first place? An infrared LED and detector will work very well. With the microphone you have to account for the time it takes the sound to travel to the transducer.
straight answer, har har."
Sceadwian is offline
Old 2nd November 2009, 06:36 AM   #12
I agree. An optical sensor ABOVE the camera will give much better timing as it is independent of drop frequency, and gravity is constant so the drops fall at the same speed after triggering the sensor and will be at the same position in height when the flash goes off.
Mr RB is online now
Old 2nd November 2009, 01:14 PM   #13
well..i guess I'll use the dark trigger sensor of my circuit
gvi70000 is offline
Old 2nd November 2009, 04:58 PM   #14
Are you using the Cmos LMV722 dual opamp?
The circuit will not work with many ordinary opamps.
The Cmos opamp has a gain of about 4000 which is more than enough. But the transistor that feeds it is saturated because the trimpot is not set correctly for it to be an amplifier. The trimpot needs to be set to about 1.4k which is impossible with a 500k trimpot. Try a 5k trimpot instead and adjust it near one end so that faint background sounds trigger the circuit.
Or remove the transistor that is not biased correctly.
You might as well remove the diode that does nothing in this circuit.
audioguru is offline
Old 2nd November 2009, 05:09 PM   #15
yes, I'm using lmv722m as a comparator
unfortunately i disassemble that mic circuit
now I'm using this one but it actually is worst that the one before
PS: The 1n4148 i forgot to delete it from the simulation circuit, i didn't use it in the circuit
i was too when i test the circuit for the first time
gvi70000 is offline
sound, trigger
Light Sound Trigger gvi70000 Electronic Projects Design/Ideas/Reviews 4 11th October 2009 06:04 PM
Microwave Making Buzzing Sound [Sound Clip Included] ParkingLotLust Repairing Consumer Electronics 20 1st October 2009 09:35 PM
Strobe sound-to-light pulse trigger circuit. simontay1984 Electronic Projects Design/Ideas/Reviews 4 13th June 2008 04:40 PM
scr trigger?? bulla Electronic Projects Design/Ideas/Reviews 2 20th March 2008 09:13 PM
Sound Vs Anti-sound? Megamox General Electronics Chat 3 20th February 2005 11:38 PM
