Old 2nd November 2009, 05:29 PM   #16
do you think it is ok to remove the transistor?
Because i forgot to mention that between the op amp and the transistor circuit i use a stereo cable about 1m long
gvi70000 is offline
Old 2nd November 2009, 06:14 PM   #17
If the 100k trimpot is set to about 105k (plus and minus depending on the gain of the transistor) then the circuit will be very sensitive. But since the transistor does not have any DC negative feedback then it is also sensitive to temperature changes.
The transistor will also amplify changes in the supply voltage.
I was taught that such a simple transistor circuit should never be used for anything.
audioguru is online now
Old 2nd November 2009, 09:32 PM   #18
Thanks again for replaying Audioguru,
I've change the pot with one of 10k + ore 10k resistor in parallel(i don't have a 5k right now) and the result was almost the same in sensitivity..so i change the 2n2222 with a bc547 (measured gain is 650) and the sensitivity has increase a little bit. Maybe the mic is not sensitive enough - i think is a Velleman with a sensitivity around -68dB and a nominal voltage of 4.5V - next week i will receive a new mic BCM-9767P from BE-STAR -44±2dB (VS=3V/RL=2,2kΩ) i hope that will do the job.
Do you think is a good idea to remove the transistor near the mic as i connect the mic preamp with lmv722 input with a stereo shielded cable about 1m long?
gvi70000 is offline
Old 2nd November 2009, 10:35 PM   #19
You need to learn about transistors to see that yours were designed completely wrong.
If you bias the opamp properly and use negative feedback then it should work fine without a transistor. But that opamp has a much lower max gain than normal opamps.
I don't know if the very short sound duration is enough to trigger your camera.
Old 3rd November 2009, 08:59 PM   #20
How about this one?
gvi70000 is offline
Old 3rd November 2009, 10:51 PM   #21
It is good that the first transistor has a bypassed emitter resistor for good DC stability.
The second transistor is not needed.
Maybe an adjustment should be available to set the sensitivity.
Please connect a resistor in series with the base of the 3rd transistor to limit its base current.
Old 4th November 2009, 02:37 PM   #22
sorry,
I'm a little bit confused... Correct me if I'm wrong
1. Replace R3 10k with a pot (i think same value...maybe 15k)
2. I have to connect a resistor at the base of Q2 (because i only have 2 transistors in the circuit) but if i put a 1k resistor the amplification after Q2 will be smaller than the on give by Q1 - i didn't simulate the circuit but i think that the Vout from Q2 is smaller with at least 0.7V
gvi70000 is offline
Old 4th November 2009, 03:42 PM   #23
I don't know why you are using a preamp with two transistors when only one properly biased transistor is needed.
If the preamp works then don't change its parts, instead make the R8/R9 voltage divider adjustable for sensitivity.
Old 4th November 2009, 03:49 PM   #24
Thanks,
I will try that and let you know the result.
I know that i'm annoying with my questions, but this is by far the most complicated project that i made so far. I tray to learn by myself but some times i get no results...and i become annoying.
Thanks again.
gvi70000 is offline
sound, trigger
Light Sound Trigger gvi70000 Electronic Projects Design/Ideas/Reviews 4 11th October 2009 06:04 PM
Microwave Making Buzzing Sound [Sound Clip Included] ParkingLotLust Repairing Consumer Electronics 20 1st October 2009 09:35 PM
Strobe sound-to-light pulse trigger circuit. simontay1984 Electronic Projects Design/Ideas/Reviews 4 13th June 2008 04:40 PM
scr trigger?? bulla Electronic Projects Design/Ideas/Reviews 2 20th March 2008 09:13 PM
Sound Vs Anti-sound? Megamox General Electronics Chat 3 20th February 2005 11:38 PM
