Hello there, I'm new this stuff and don't know much. I have a question here. I have a Twin Motor Gear Box (Twin Motor Gearbox) that uses two FA-130 motors ( Mabuchi FA-130 Motor) and 2 D Cell Batteries (D Cell Batteries I use are about 1.5V-8000mAh). I need to run the motors as fast and as strong as possible with the 2 D Cell batteries, it doesn't matter that the batteries last 10 minutes. I was thinking of connecting the batteries in series which will give me 3V-8000mAh. Then have a circuit that will change 3V-8000mAh into about 6V-2500mAh. I need help finding the circuitry that will do that. I know the circuit won't have 100% efficiency, I'm only looking for about 50-70% efficiency. Battery run time does not matter, I only need about 10 minutes of run time. Currently the batteries will run the motors for 1 day, batteries in series, motors in parallel. I don't really know what to search on google, so any help is appreciated. If anything I said up there is wrong, please correct me. If any of this doesn't make sense, please ask. I really need help. All help appreciated. Thanks in advance. Thanks. | |
Have you tried hooking the motors to 4 D-cells in series to see if the 1.5v-3v motor will last 10 minutes at 6v? Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| | #3 | |
__________________ Proper Planning Prevents Piss Poor Performance | ||
Yeah... ...but, better than spending the time and money building a DC-DC inverter...only to come out with the same result. ![]() Ken
I would definitely try that first =) If you stall those motors at twice the voltage the coils will probably melt into little puddles =\ Instead of 2 D's How about using 3 C cells?
| | #6 |
The motors can run at 6V from 4 D Cells easily. They don't burn out and run perfectly fine for much more then 10 minutes. Is there a way to get the same speed and power from only 2 D Cells, less run time does not really matter, I only need about 10 minutes, before I change the batteries. The person who asked about 3 C Cells instead of 2 D Cells, I can only use D Cell Batteries. | |
| | #7 |
Is this for a competition or school project...thus the limitation? Ken
| | #8 |
Well you'd need an oscillator circuit powering a transistor to pulse a step up transformer the re-rectify it to power the motor, problem is the voltage is so low you'd be lucky to get 25% efficiency out of it, the other 75% would be wasted as heat. You really need to add more cells in series to get a higher voltage with any degree of usability. The batteries simple can't provide enough current after conversion losses.
| | #9 |
@KMoffett: This is for a robotics race, that's why there's these restrictions. @Sceadwian: I didn't get what you said in the first part, haha, if you say efficiency if about 25%, then 3V-8000mAh would equal to about 6V-1000mAh. And what I'm getting that your saying is, I won't be able to run the motor any better then if I connected them to the motor directly. Right? So it's not possible? | |
| | #10 |
Impossible? Not really, but not exactly practical (with limited knowledge). You're looking for a 2A boost converter that accepts an input of 2.4 volts. One thing that might help is an external low current source of 6-12V to bootstrap it. If you don't already have 6V, then you could build a LM2698 circuit with about 9 components for up to $6. This won't be beefy enough to drive the motor. Then you could use a fairly common boost controller to drive the gate of a couple of MOSFETs. I say a couple, because you'll need multiple switches to keep the ripple in the battery down.
__________________ de KI6RWX | |
| | #11 |
mneary, think about the efficiency for a few minutes, then get come back to this post =) We're not talking advanced semi conductor electronics and a high degree of circuit prep. The OP has much simpler goals.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 5th November 2009 at 02:59 AM. | |
| | #12 |
| Considering his starting point, true. If he can't handle the LM2698 for starters, his project is dead. Kind of an entrance exam. ![]() Maybe I'll try to build one and see where the problems lie.
| hobby, motor, running |
| Crazy RC Project Hobby 350W 24VDC Motor | zeppblimp | General Electronics Chat | 7 | 6th June 2009 12:32 AM |
| 12V motor running at 60 RPM | oliveros | Electronic Projects Design/Ideas/Reviews | 13 | 17th May 2009 03:48 PM |
| Running a DC motor | neo_star | Electronic Projects Design/Ideas/Reviews | 2 | 28th March 2009 11:06 AM |
| Motor Running Sensor ? | aljamri | Electronic Projects Design/Ideas/Reviews | 15 | 14th August 2008 02:07 PM |
| How do I wire a potentiometer to a hobby motor? | froggy | General Electronics Chat | 4 | 14th December 2007 07:49 PM |
