Old 2nd November 2009, 10:42 PM   #31
You can use nichrome wire, it is inside hair dryers. Just buy a cheap hair dryer, unwind the heating element (nichrome wire). For power control you can use PWM from an LM555 to drive a large transistor. Find out how many amps the transistor needs to be rated for by looking at the wattage on the hair dryer. Also, the heating element will work just fine with rectified DC which is what you are going to need for the transistor. The thermostat will be the duty cycle control on the LM555.
MOSFET KILLER is offline
Old 3rd November 2009, 03:07 AM   #32
i got the wire off of ebay it was the biggest gauge they offered in 100'.
cbiblis is online now
Old 5th November 2009, 09:45 AM   #33
You could buy a hair dryer and just use the element.and fan (just take off the pretty plastic case. or not.). Get a 220V unit, it will operate at 1/4 rated power on 120. You can get cheap "travel" units for as little as $6.
I would be a little concerned about motor reliability, but at 1/2-1/4 speed it might be satisfactory.
de KI6RWX
mneary is offline
100, box, cu or ft, degrees, heat, heater, resistor
testing a lm335 at 35 degrees cbiblis General Electronics Chat 27 26th October 2009 07:39 AM
How to build a TRON BOX or POWER BOX naidra Electronic Projects Design/Ideas/Reviews 6 14th March 2009 11:39 PM
Making Servo rotate 180 degrees streamline Robotics Chat 3 14th November 2008 08:45 PM
Magic mystery box (giving away a small box of parts) FirefighterBlu3 General Electronics Chat 4 15th October 2008 04:17 AM
Gyro degrees/second futz Micro Controllers 25 8th May 2008 06:23 AM
