Old 5th July 2004, 05:42 PM   #1
Default Need help For Thesis About An 8 Watt Audio Amplifier
Can i get help from anyone...basically everythin bout it...I am currently building a PC speaker which consist of this 8 w amp and using the IC of D2822A...i cant seem to get a datasheet of that IC...need every information needed about the operation of the IC and all the components that connect around it...thank you...
Jajazz is offline
Old 5th July 2004, 07:15 PM   #2
The number you supplied is probably a manufactures item number and not a universal part designator .
The TDA series amps are mono and stereo amps the TDA 2822 is a 12W x 2 amp in a dip. http://www.st.com/stonline/books/pdf/docs/1462.pdf
A single to-220 8W mono amp is a TDA 2002. http://www.nteinc.com/specs/1200to1299/pdf/nte1232.pdf
I just guessing here but do you have the part in hand?
TillEulenspiegel is offline
Old 6th July 2004, 12:07 PM   #3
thanx for the help man...tda2822 seems the better bet...but it has 16 pins...mine has 8 pins only...yes i do have it with me...do u know of anyone's site which he/she did the same thesis as mine...need examples here...
Jajazz is offline
amplifier, audio, thesis, watt
