I builded a dc power suply, and i want to add an indicator with led which turns on when a load is well connected to the power suply. in other words I need to build a load indicator in my power suply. any help on how to do that ? I have been seeing this feature in some phone chargers. | |
As you built the supply, Increase the output voltage by 2V. Add a resistor that will drop two volts at the load current. Put an LED across the resistor. If that don't work, try explaining what you are doing better. Mike. | |
| | #3 | |
Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 27th October 2009 at 02:36 PM. | ||
| | #4 | |
. Plus, resistors are cheaper than diodes.![]() BTW, why 1.8V, you using germanium diodes? And, with 1.8V your LED won't light will it? Got it, you're a teacher? They're still using germanium diodes. ![]() Mike. Above all said with tongue firmly placed between molars. | ||
let me give an instance, I have a 12v power suply with two wires connected as output (vcc and gnd). my question is: if i power my fm radio with that my 12v power supply output, a green LED shuld turn on. how do i go about that? Thanks
| | #6 |
Connect the green LED with a suitable resistor to your radio. What are you trying to achieve? Do you not hear the radio when its on? Mike. | |
| | #7 |
I want that LED to turn on even if i connected any other circuit to that power suply. I dont need to alter any other circuit apart from my power suply.
| | #8 | |
Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 27th October 2009 at 03:38 PM. Reason: Added more | ||
| | #9 |
Post a schematic of your supply. It may be easy after we see what you are doing.
__________________ Mike ML. | |
| indicator, led, load |
| over-load indicator | georgetwo | General Electronics Chat | 7 | 27th September 2009 01:39 AM |
| Need LED load indicator | highveelocity | Electronic Projects Design/Ideas/Reviews | 8 | 2nd March 2009 12:27 AM |
| Using a 2N7000 LED indicator, will it not load down an input? | blueroomelectronics | Electronic Projects Design/Ideas/Reviews | 21 | 10th February 2008 06:32 PM |
| LED indicator | E2K | Electronic Projects Design/Ideas/Reviews | 6 | 29th October 2007 09:48 AM |
| load indicator circuit | gaurav | General Electronics Chat | 4 | 31st May 2003 12:27 AM |
