In my project I need to control intensity of 8 LED Piranha by using following components(see an attached file): - LED RGB Controller ( simply changes combination of R,G,B colors) - OPTO22 ODC15 Solid state relays module - 8 independent PWM controllers (work from software and change output voltage from 0 to 12VDC) - 8 LED RGB Piranha 12VDC, 25mA, with resistors My point is to make dimmable 8 LED Piranha while the LED Controller changes colors. Each LED performs according to the PWM Controller output voltage. I've already made and tested only one LED. Works perfect. Don't know where to connect other 7 negative outputs from PWM's. Do I have to have 7 more OPTO22 or there is another solution? Need help. Thank you. | |
| controllers, controlling, led, piranha, pwm |
| PWM Controllers & BJTs | Carel_Integrated | General Electronics Chat | 0 | 17th July 2009 01:23 AM |
| Controlling servo's with PWM and flex sensor's ? Needing some help | Darkstar64 | Micro Controllers | 0 | 5th February 2009 11:53 PM |
| PWM speed controlling | civictypeR | Electronic Projects Design/Ideas/Reviews | 0 | 29th January 2008 03:42 PM |
| Piranha LEDs | HarveyH42 | General Electronics Chat | 21 | 13th July 2006 07:30 PM |
| Cuk converter PWM controllers? | Schneibster | Electronic Projects Design/Ideas/Reviews | 30 | 2nd May 2005 10:04 AM |
