Hi there! Could someone give me an idea? I need some sort of pressure sensitive pad that is: - Fairly large (around 100 x 60 cm). - Flexible. - Waterproof. - Does not float. - Resistant to rough treatment. - Can give me some sort of electric signal when briefly stepped on or kicked. Hopefully it will be a simple on/off signal, but if needed I can measure, for example, a change of resistance... *** Something else, ideally it would be a material which I can handle and use on whatever I need and will be cheaper than buying a bunch of premanufactured re-mortgage-your-house security pads because I need loads of them... Someone once told me about a certain conductive foam which would chance resistance when under pressure, ever heard of it? The only problem is that being a foam it will not be heavier than water and will not sink... Any ideas? Thanks.
__________________ "I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison | |
What you are describing here is comonly used in industry and it's known as safety mat. There are many brands so you will have to google a bit to find what you like. Companies that deal with safety are for example Sick, Banner, Sti, Honeywell, Keyence and many more. | |
Those pads used to be used to open doors automatically at stores, etc. These days, they often use ultrasonic or microwave sensors for that. Here's a link for a pressure-sensitive mat which can be used for home security alarms: http://www.smarthome.com/5195.html Might be just what you're looking for. This one might not be waterproof though. JB | |
Thanks for your tips! I just edited the post to add an aditional note... (And fixed a typo too... 8) )
This type of mat is used in the alarm business also.It's placed under carpeting. It's usually normally open , closed when stepped on..
__________________ gerty | |
| | #6 |
__________________ Mark Higgins | |
| pad, pressure, sensitive |
