Old 24th October 2009, 12:42 PM   #16
Originally Posted by MrDEB View Post
in order for relay to energize
hope I got this right??
Under what conditions do you want the relay to be energised.?
Please post your asc file.
ericgibbs is offline
Old 24th October 2009, 12:42 PM   #17
Originally Posted by ericgibbs View Post
Why do you think you are offending me.
Like you I dont not know for sure what the OP wants to do.
I assumed that the mention of two diodes would start bells ringing in MrDebs head, as a possible solution.
In the end, your solution seems to be good one, was not trying to jab you, ya know I luv ya man.
Pay it forward.
Mikebits is offline
Old 24th October 2009, 02:57 PM   #18
Default lets try the asc file
hope this works
MrDEB is online now
Old 24th October 2009, 03:03 PM   #19
Default another project
it works in simulation
MrDEB is online now
Old 24th October 2009, 03:18 PM   #20
Look at these two modified asc.
When is the battery monitor supposed to switch on/out.?
Old 24th October 2009, 03:23 PM   #21
Originally Posted by Mikebits View Post
Not quite, two diodes reversed bias with pullup will make And gate.
Hi Mike,
Well Mike, that's your version. Mine uses three :-)
I was going to use a third diode just to make sure the
transistor turns off fully. With two diodes and pullup, there could
still be as much as 0.6v at the base of the transistor. With an
extra diode in series with the transistor base and a light pulldown
on the base, the transistor base sees about 0.15v and turns off
fully. Depending on load it may work anyway, but it could be close
without the extra diode, not something i would be comfortable with.
Another version would put the extra diode in series with the emitter
if power considerations allow.
Still yet another version could use an extra resistor to divide the
diode voltage down so the base sees about 1/2 a diode drop instead
of the whole diode drop.
That reply was a little joking too BTW :-)
MrAl is online now
Old 24th October 2009, 05:13 PM   #22
Default R6 and R7 is supposed to be a pot
hav'nt figured out how to use a pot (variastor) in spice.
and how do you get the triangle wave??
the monitor is supposed to be adjusted to close relay at around 10-11 volts
I played with it in spice as well as Tina (Tina dosn't have an op amp with single supply) but it still worked.
still trying to figure out all the little things in spice = multi planes, varistors, steeping through the battery voltages(change from 12 to 11 to 10 etc. to see the circuit in operation.
we is learning
will look at your sims and decipher. what did you change??
MrDEB is online now
Old 24th October 2009, 05:21 PM   #23
Why not use the 'voltage' model and set the V range to suit
Use the PWL piece wise list
You can see that list I entered,modify it to suit your app
we is learning
If you have a query, please ask, post your asc file so that we can edit it and post it back, OK.?
LTSpice Tutorial
Old 24th October 2009, 05:30 PM   #24
Default Thanks
will try out the voltage model. need to locate first = lol
MrDEB is online now
Old 24th October 2009, 05:39 PM   #25
Default took out battery, inserted voltage
got it working
thanks
wondered what pwr was??
MrDEB is online now
Old 24th October 2009, 05:40 PM   #26
On the schematic part press F2 key then select 'voltage'
Old 25th October 2009, 02:59 AM   #27
Default I tried everything but!!
couldn't get the relay to open using a PNP transistor
resorting to opticolupter
looks like it works??
MrDEB is online now
Old 25th October 2009, 01:45 PM   #28
Default now I is in mud
trying to sim a simple relay being controlled by an op amp
got the LEDs to work but tried inserting a pnp transistor - nada
I figure the LED works so insert an opticoupler
still isn't right??
Getting really lost in Idaho
something so simple and run into a snow storm
MrDEB is online now
Old 25th October 2009, 02:23 PM   #29
still isn't right??
hi
Look at the V symbols... you have +v and v+..... they are different!!!!
Old 25th October 2009, 02:27 PM   #30
hi
Good eye Eric
Pay it forward.
Mikebits is offline
amp, circuit, comparator
Comparator circuit, op-amp exam question help shorty864 General Electronics Chat 7 23rd January 2009 04:14 PM
Comparator circuit + OP Amp 741 help Hussain Electronic Projects Design/Ideas/Reviews 10 22nd January 2009 12:50 PM
Please Help ADC & Comparator Edy_Tse88 Micro Controllers 2 8th December 2007 05:32 PM
LM347 comparator/op-amp erictham83 Datasheet/Parts Requests 9 26th August 2006 03:32 AM
learning op amp comparator reference volatge waqar General Electronics Chat 1 6th April 2003 10:42 PM
