| Supply voltage +/-1.0V power<500uW low-frequency gain 30-50dB maxiumum gain variation(0<f<20MHz,0C<T<80C) <+/-1dB differential Output Swing >+/-1.2V | |
| What do you want to know? What are you trying to do? Listing the information you have is insufficient. How a device is made or to what scale - 0.18um - has very little to do with a circuit you may wish to make. Have you a particular device(s) in mind? Have you located the datasheet or applications note for the device(s)? | |
| The tesmc018 file is attached . I want to design a variable-gain amplifier.In order to meet low power consumption, the total current should be less than 250uA.it is also difficult to reduce the output resistance to meet the maximum gain variation to meet <+/-1 db | |
| The tesmc018 file is attached . I want to design a variable-gain amplifier.In order to meet low power consumption, the total current should be less than 250uA.it is also difficult to reduce the output resistance to meet the maximum gain variation to meet <+/-1 db MOSIS file tsmc-018/t29b_mm_non_epi-params.txt MOSIS PARAMETRIC TEST RESULTS RUN: T29B (MM_NON-EPI) VENDOR: TSMC TECHNOLOGY: SCN018 FEATURE SIZE: 0.18 microns INTRODUCTION: This report contains the lot average results obtained by MOSIS from measurements of MOSIS test structures on each wafer of this fabrication lot. SPICE parameters obtained from similar measurements on a selected wafer are also attached. COMMENTS: DSCN6M018_TSMC TRANSISTOR PARAMETERS W/L N-CHANNEL P-CHANNEL UNITS MINIMUM 0.27/0.18 Vth 0.51 -0.51 volts SHORT 20.0/0.18 Idss 546 -256 uA/um Vth 0.51 -0.51 volts Vpt 4.8 -5.5 volts WIDE 20.0/0.18 Ids0 13.2 -6.7 pA/um LARGE 50/50 Vth 0.43 -0.42 volts Vjbkd 3.2 -4.1 volts Ijlk <50.0 <50.0 pA Gamma 0.53 0.62 V^0.5 K' (Uo*Cox/2) 171.4 -34.7 uA/V^2 Low-field Mobility 397.10 80.39 cm^2/V*s COMMENTS: Poly bias varies with design technology. To account for mask and etch bias use the appropriate value for the parameters XL and XW in your SPICE model card. Design Technology XL XW ----------------- ------- ------ SCN6M_DEEP (lambda=0.09) -0.02 -0.01 thick oxide -0.03 -0.01 TSMC18 -0.02 0.00 thick oxide -0.02 0.00 SCN6M_SUBM (lambda=0.10) -0.04 0.00 thick oxide -0.07 0.00 FOX TRANSISTORS GATE N+ACTIVE P+ACTIVE UNITS Vth Poly >6.6 <-6.6 volts PROCESS PARAMETERS N+ACTV P+ACTV POLY N+BLK PLY+BLK MTL1 MTL2 UNITS Sheet Resistance 6.7 7.5 7.8 59.2 337.1 0.08 0.08 ohms/sq Contact Resistance 11.3 11.8 10.2 6.59 ohms Gate Oxide Thickness 40 angstrom PROCESS PARAMETERS MTL3 POLY_HRI MTL4 MTL5 MTL6 N_WELL UNITS Sheet Resistance 0.08 1929.0 0.08 0.08 0.03 925 ohms/sq Contact Resistance 11.97 17.82 23.86 26.28 ohms COMMENTS: BLK is silicide block. CAPACITANCE PARAMETERS N+ACTV P+ACTV POLY M1 M2 M3 M4 M5 M6 M5P N_WELL UNITS Area (substrate) 971 1162 105 38 18 13 8 8 3 67 aF/um^2 Area (N+active) 8526 53 19 13 11 9 8 aF/um^2 Area (P+active) 8214 aF/um^2 Area (poly) 63 16 10 7 5 4 aF/um^2 Area (metal1) 35 14 9 6 5 aF/um^2 Area (metal2) 37 14 9 6 aF/um^2 Area (metal3) 41 15 9 aF/um^2 Area (metal4) 38 13 aF/um^2 Area (metal5) 33 1010 aF/um^2 Area (no well) 138 aF/um^2 Fringe (substrate) 258 203 -- 59 53 42 23 -- aF/um Fringe (poly) 66 38 28 23 20 17 aF/um Fringe (metal1) 53 34 22 19 aF/um Fringe (metal2) 53 35 27 22 aF/um Fringe (metal3) 53 35 28 aF/um Fringe (metal4) 55 35 aF/um Fringe (metal5) 57 aF/um Overlap (N+active) 716 aF/um Overlap (P+active) 679 aF/um CIRCUIT PARAMETERS UNITS Inverters K Vinv 1.0 0.75 volts Vinv 1.5 0.79 volts Vol (100 uA) 2.0 0.08 volts Voh (100 uA) 2.0 1.62 volts Vinv 2.0 0.83 volts Gain 2.0 -24.39 Ring Oscillator Freq. D1024_THK (31-stg,3.3V) 291.97 MHz DIV1024 (31-stg,1.8V) 359.22 MHz Ring Oscillator Power D1024_THK (31-stg,3.3V) 0.07 uW/MHz/gate DIV1024 (31-stg,1.8V) 0.02 uW/MHz/gate COMMENTS: DEEP_SUBMICRON T29B SPICE BSIM3 VERSION 3.1 PARAMETERS SPICE 3f5 Level 8, Star-HSPICE Level 49, UTMOST Level 8 * DATE: Dec 9/02 * LOT: T29B WAF: 6003 * Temperature_parameters=Default .MODEL CMOSN NMOS ( LEVEL = 49 +VERSION = 3.1 TNOM = 27 TOX = 4E-9 +XJ = 1E-7 NCH = 2.3549E17 VTH0 = 0.3627858 +K1 = 0.5873035 K2 = 4.793052E-3 K3 = 1E-3 +K3B = 2.2736112 W0 = 1E-7 NLX = 1.675684E-7 +DVT0W = 0 DVT1W = 0 DVT2W = 0 +DVT0 = 1.7838401 DVT1 = 0.5354277 DVT2 = -1.243646E-3 +U0 = 263.3294995 UA = -1.359749E-9 UB = 2.250116E-18 +UC = 5.204485E-11 VSAT = 1.083427E5 A0 = 2 +AGS = 0.4289385 B0 = -6.378671E-9 B1 = -1E-7 +KETA = -0.0127717 A1 = 5.347644E-4 A2 = 0.8370202 +RDSW = 150 PRWG = 0.5 PRWB = -0.2 +WR = 1 WINT = 1.798714E-9 LINT = 7.631769E-9 +XL = -2E-8 XW = -1E-8 DWG = -3.268901E-9 +DWB = 7.685893E-9 VOFF = -0.0882278 NFACTOR = 2.5 +CIT = 0 CDSC = 2.4E-4 CDSCD = 0 +CDSCB = 0 ETA0 = 2.455162E-3 ETAB = 1 +DSUB = 0.0173531 PCLM = 0.7303352 PDIBLC1 = 0.2246297 +PDIBLC2 = 2.220529E-3 PDIBLCB = -0.1 DROUT = 0.7685422 +PSCBE1 = 8.697563E9 PSCBE2 = 5E-10 PVAG = 0 +DELTA = 0.01 RSH = 6.7 MOBMOD = 1 +PRT = 0 UTE = -1.5 KT1 = -0.11 +KT1L = 0 KT2 = 0.022 UA1 = 4.31E-9 +UB1 = -7.61E-18 UC1 = -5.6E-11 AT = 3.3E4 +WL = 0 WLN = 1 WW = 0 +WWN = 1 WWL = 0 LL = 0 +LLN = 1 LW = 0 LWN = 1 +LWL = 0 CAPMOD = 2 XPART = 0.5 +CGDO = 7.16E-10 CGSO = 7.16E-10 CGBO = 1E-12 +CJ = 9.725711E-4 PB = 0.7300537 MJ = 0.365507 +CJSW = 2.604808E-10 PBSW = 0.4 MJSW = 0.1 +CJSWG = 3.3E-10 PBSWG = 0.4 MJSWG = 0.1 +CF = 0 PVTH0 = 4.289276E-4 PRDSW = -4.2003751 +PK2 = -4.920718E-4 WKETA = 6.938214E-4 LKETA = -0.0118628 +PU0 = 24.2772783 PUA = 9.138642E-11 PUB = 0 +PVSAT = 1.680804E3 PETA0 = 2.44792E-6 PKETA = 4.537962E-5 ) * .MODEL CMOSP PMOS ( LEVEL = 49 +VERSION = 3.1 TNOM = 27 TOX = 4E-9 +XJ = 1E-7 NCH = 4.1589E17 VTH0 = -0.4064886 +K1 = 0.5499001 K2 = 0.0389453 K3 = 0 +K3B = 11.4951756 W0 = 1E-6 NLX = 9.143209E-8 +DVT0W = 0 DVT1W = 0 DVT2W = 0 +DVT0 = 0.5449299 DVT1 = 0.3160821 DVT2 = 0.1 +U0 = 117.9612996 UA = 1.64867E-9 UB = 1.165056E-21 +UC = -1E-10 VSAT = 2E5 A0 = 1.7833459 +AGS = 0.407511 B0 = 1.314603E-6 B1 = 5E-6 +KETA = 0.0137171 A1 = 0.4610527 A2 = 0.6597363 +RDSW = 364.9443889 PRWG = 0.5 PRWB = -0.1129203 +WR = 1 WINT = 0 LINT = 2.007556E-8 +XL = -2E-8 XW = -1E-8 DWG = -2.835566E-8 +DWB = 8.003075E-9 VOFF = -0.1064646 NFACTOR = 2 +CIT = 0 CDSC = 2.4E-4 CDSCD = 0 +CDSCB = 0 ETA0 = 0.0141703 ETAB = -0.0398356 +DSUB = 0.4441401 PCLM = 2.2364512 PDIBLC1 = 9.167645E-4 +PDIBLC2 = 0.0209189 PDIBLCB = -9.568266E-4 DROUT = 9.976778E-4 +PSCBE1 = 1.731161E9 PSCBE2 = 5E-10 PVAG = 14.337819 +DELTA = 0.01 RSH = 7.5 MOBMOD = 1 +PRT = 0 UTE = -1.5 KT1 = -0.11 +KT1L = 0 KT2 = 0.022 UA1 = 4.31E-9 +UB1 = -7.61E-18 UC1 = -5.6E-11 AT = 3.3E4 +WL = 0 WLN = 1 WW = 0 +WWN = 1 WWL = 0 LL = 0 +LLN = 1 LW = 0 LWN = 1 +LWL = 0 CAPMOD = 2 XPART = 0.5 +CGDO = 6.79E-10 CGSO = 6.79E-10 CGBO = 1E-12 +CJ = 1.176396E-3 PB = 0.8607121 MJ = 0.4163285 +CJSW = 2.135953E-10 PBSW = 0.6430918 MJSW = 0.2654457 +CJSWG = 4.22E-10 PBSWG = 0.6430918 MJSWG = 0.2654457 +CF = 0 PVTH0 = 4.364418E-3 PRDSW = 4.4192048 +PK2 = 3.104478E-3 WKETA = 0.0270296 LKETA = 2.038008E-3 +PU0 = -2.3639825 PUA = -8.41675E-11 PUB = 1E-21 +PVSAT = -50 PETA0 = 1E-4 PKETA = -1.444802E-3 ) * Download Text File | |
