Old 22nd October 2009, 08:44 PM   #1
Default Replace reed switch with something else to continually close/open circuit
I have a device with a magnetic reed switch.
I want to replace the reed switch with something that will close/open the circuit continually, adjustable to anywhere from perhaps once per second to perhaps 4 times per second.
I imagine that the heart of this would be a 555 chip, but that's about all I (think) that I know. I have never constructed anything like this before.
Are there any simple plans anywhere to accomplish something like this?
Thanks,
Randyu
ghh3rd is offline
Old 22nd October 2009, 10:01 PM   #2
Need to know the voltage and current the reed switch is switching.
Why not just control the reed switch with a 555?
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 22nd October 2009, 10:14 PM   #3
Good idea. Leaving the reed switch in place, and using a 555 to control it would definitly seem like a better solution.
Now, can anyone point out a good way to do this? Only one speed is necessary. Perhaps I could tweak the circuit until I get to the desired speed?
Thanks,
Randy
ghh3rd is offline
Old 23rd October 2009, 01:26 PM   #4
Can you please elaborate on how to use the 555 to control the reed switch?
Thanks - Randy
ghh3rd is offline
Old 23rd October 2009, 02:52 PM   #5
Configure 555 to Astable configuration.Google for NE555 Astable circuits.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 23rd October 2009, 07:12 PM   #6
Gayan,
Will do -- but the reed switch requires a magnetic field; how will the 555 actually 'control' the switch?
Sorry if my question sounds obvious, but I'm new at this. I'd really like to get into building and eventually being able to design components.
Randy
ghh3rd is offline
Old 23rd October 2009, 11:00 PM   #7
I take it the reed switch is activated by a magnet normally.
In that case you would need to wind a coil around the switch. Any small tube (straw) that just fits over the reed should work as a coil form. Then you need to wind many turns of as fine a wire as you can find (such as 30Ga or finer). You will have to experimentally determine how many turns and how much current it takes to activate the switch. From that you can calculate the voltage and resistance in series with the coil will provide the required current.
Otherwise just substitue a reed relay for the reed switch. They have the coil already wound.
Carl
Old 24th October 2009, 02:20 PM   #8
Thanks for the explanation crutschow.
ghh3rd is offline
circuit, close or open, continually, reed, replace, switch
Needing help to replace rotary switch with digital circuit Brian1 Electronic Projects Design/Ideas/Reviews 15 5th October 2009 07:25 PM
Automatically Open/Close the Gate? r.vittalkiran General Electronics Chat 1 5th September 2009 12:05 PM
Fast Way To Open/close A Butterfly Valve fastline Robotics Chat 16 5th March 2009 04:05 PM
12v DC motor to open and close a door b***nb Electronic Projects Design/Ideas/Reviews 6 5th March 2009 02:42 PM
close a circuit by 0v switch lazynok Electronic Projects Design/Ideas/Reviews 5 10th June 2003 10:42 AM
