Hello friends.. I want to transmit 40 kHZ square wave signal from 89c51RD2 pin over a distance of 25-30 meters and drive an Infrared LED(it requires about 50-100mA current) with it. Is it feasible? What circuitry is recommended? I propose using current amplifier first near the port pin increasing the current level to about 50 mA (voltage level is 4.4 V) , and then transmit the signal 30 meters using CAT 5 and finally ZTX601(darlingon pair) to drive the LEDs . Is it enough or too much ? Is it possible to get rid of one of the two transistors I am using? What is the minimum current required to faithfully transmit 40kHz (4.4V peak) square wave through the CAT 5 cable for 30 meters to drive the LEDs using/without using the transistor? Please shed some light! Thank You! | |
No Ideas Friends?
To do it professionally I'll use MAX485 chips combining your micro. You send 40Khz from micro to MAX485 "DI" pin & it will send the data via the two balanced lines.In receive side I'll take that two signal wires & input to MAX485 & take data out from "RO" pin & boost via a transistor. See how neat is that? | |
| cat, current, meters, minimum |
| Meters? | Silverbullet | General Electronics Chat | 16 | 3rd June 2009 09:21 PM |
| Incuctance Meters | Bob Scott | General Electronics Chat | 2 | 16th April 2008 06:08 AM |
| distance meters | hjl4 | Electronic Projects Design/Ideas/Reviews | 5 | 4th September 2006 07:14 PM |
| Signal meters | KDANDAVATE | General Electronics Chat | 1 | 6th October 2004 12:15 PM |
| minimum current into an input pin | SupeR-NovA | Micro Controllers | 5 | 2nd April 2004 03:04 PM |
